VS Pro X9 Doesn't Recognize My Camcorder
DayO
motherboard: HP 18E7
processor: Intel Core i5 4750 CPU 3 20 GHz
ram: 32 GB
Video Card: Intel HD Graphics 4600 1024 MB
Hard_Drive_Capacity: 3932 GB
Corel programs: Video Studio Pro X9
Post by DayO »
I recently upgraded to VS Pro X9 and just tried to Capture video from my camcorder.
VS Pro failed to detect my camcorder--via USB--for footage upload!!
What's going on here?
canuck
operating_system: Windows 8.1
Re: VS Pro X9 Doesn't Recognize My Camcorder
Post by canuck »
Does Windows see your camcorder?
What is make/model of your camcorder?
There is very little information in your post to be able to help you
Terfyn
motherboard: ASUSTeK P8H61-MX
processor: Intel Corei5-2320
ram: 8Gb
Video Card: NVIDIA GeForce 210
sound_card: NVIDIA High Def Audio
Hard_Drive_Capacity: 1000 Gb
Monitor/Display Make & Model: Acer & LG
Corel programs: VS X10 and PSP X8
Post by Terfyn »
Whatever your setup , it is better to download the video files to your PC using the normal Windows actions then open them in VS. Two steps are often better than one.
BJC
Hard_Drive_Capacity: 1TB
Corel programs: Videostudio X10 and 2020
Post by BJC »
has any version of Videostudio ever captured your footage via USB
canuck wrote:Does Windows see your camcorder?
Is your camcorder a MiniDV that records footage to tape?
or
a model that records to SD card or internal memory within the camera?
DayO
ram: 32 GB
Post by DayO »
My version of Windows 7 Pro didn't detect my Panasonic HDC-SD90 camcorder. My earlier VS Pro X7
was detected via USB under Win 7 Pro
DayO
ram: 32 GB
Post by DayO »
BJC wrote:has any version of Videostudio ever captured your footage via USB
Yes. VS Pro X7 detected via USB my Panasonic camcorder just fine.
DayO
ram: 32 GB
Post by DayO »
or a model that records to SD card or internal memory within the camera?
Not a MiniDV, but a Panasonic HDC-SD90. It does contain an SD card.
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
But Dayo, why you need it to be detected by VS?
just copy the files with explorer and get them into VS.
Panasonic X900m, VXF1
Hi DayO
You have two options, although there are other ways.
Option 1 /
from video studio right click the timeline and choose Import Digital Media
Browse for your camcorder, may be showing as Cam_SD,.
Expand the file system till you find the AVCHD folder, place a tick in that and OK
From the next window choose Start
The next window shows the actual files as a thumbnail, select the files you need or “choose select All”
Choose a working folder to hold the files
Files will be imported with similar names as “170805_085008_import.m2t”
Option 2 /
with your camcorder connected to the pc, go to Computer ( or this PC) where you should find a removable Drive marked Cam_SD, again browse for the AVCHD folder, then find the Stream folder, here you will find your video files.
Cam_SD:\PRIVATE\AVCHD\BDMV\STREAM
Copy and paste the files to a folder on your hard drive, file names will be similar to 00002.MTS
now import the files to your library or timelines.
The advantage of option one is the unique file name that indicates the recording date.
because of that there is no possibility of overwriting previous files, option 2 uses the same file names which could be overwritten with the next import?
Make sure you create a different working folder for the next import.
DayO
ram: 32 GB
Post by DayO »
Thanks much for all these good solutions!
