VS X10 Ultimate Closes when bringing a clip into timeline
Elderly Iron
motherboard: Asus Z 87 Deluxe
processor: Intel i5
ram: 16G
Video Card: EVGA 670
Hard_Drive_Capacity: 500G SSD
Monitor/Display Make & Model: Nec 3210 & Gem GL-1920S
Corel programs: VS Pro X 9 Ultimate
Post by Elderly Iron »
Fault Module name StackHash_1dc2
Not that I haven't had constant problems with this machine, but X10 was working prior to installing Glarysoft Utilities and making performance changes in Windows 7. I created a restore point prior to the changes, and have restored the machine to the prior settings to no avail. Not only does it close the program when bringing any clip into the timeline, it also removes the new clips that were brought into the library.
Problem signature:
Problem Event Name: BEX64
Application Name: vstudio.exe
Application Version: 20.5.0.60
Application Timestamp: 599334e7
Fault Module Name: StackHash_1dc2
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Offset: 0000000000000000
Exception Code: c0000005
Exception Data: 0000000000000008
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional Information 1: 1dc2
Additional Information 2: 1dc22fb1de37d348f27e54dbb5278e7d
Additional Information 3: eae3
Additional Information 4: eae36a4b5ffb27c9d33117f4125a75c2
RobertOZ
Hard_Drive_Capacity: 7 TB
Re: VS X10 Ultimate Closes when bringing a clip into timelin
Post by RobertOZ »
That StackHash_1dc2 fault module normally indicates a conflicting program, as Glarysoft Utilities ( whatever is that program supposed to do ) is the last program you installed and as the release notes for that program state "Added support for Corel VSX10" making that program the most likely suspect, try uninstalling, making sure that you remove all traces of the program then launch VSX10 again. You have stated that you have tried a restore to a point before installing, but some registry elements could have been left behind
Elderly Iron
processor: Intel i5
ram: 16G
Will do. I've never had issue with CCleaner, so I'll load that to clear out the unused files and registry entries.
RobertOZ
Post by RobertOZ »
Many forum users use CCleaner, if that does not work then you should try uninstalling/reinstalling VSX10, as it is possible that Garysoft has corrupted the program
Elderly Iron wrote: it also removes the new clips that were brought into the library.
That is normal on any crash
If we import clips to the library and the program crashes for any reason those clips will disappear from the library.
however closing video studio in the normal manner will update the library structure, saving the changes additions etc.
Reboot Video Studio and the clips will be there even after the next crash.
I would not worry about the above as it will happen to all users, its the PC cleaner that has done the damage.
Elderly Iron
processor: Intel i5
ram: 16G
It appears that indeed I will need to re-install. No correction from doing another restore from an even earlier time. :(
