Can it be done?
RobertdB
Corel programs: Paintshop Pro 7, 8, 9, 2018
Can it be done?
Post by RobertdB »
Can you change the color of the background only, when in the foreground you have complex objects like trees with leaves, or people with hair, or animals with fur or feathers?
When it can be done using one or more of the selection tools, can you please show me the settings :)
Clip from Original image by Brian Tomcik
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Re: Can it be done?
Post by JoeB »
Is the image you posted the actual pixel size of the image you are trying to work on? If the image you are trying to work on is larger then you should post it on a site that allows posting large images so that people can download the actual size to determine what method works best. The smaller the image the more difficult it is to isolate complex objects from the background.
JoeB
Using PSP 2019 64bit
RobertdB
Re: Can it be done?
Post by RobertdB »
thanks for your reply JoeB. Unfortunately it's not my picture, so I can't share the full size file. It was just meant as an illustration of the question I have.
When you have complex shapes, how to make a decent selection?
flagpole
motherboard: Gigabyte B450 AORUS ELITE DDR4 USB 3.1 RGB
processor: Ryzen 2600
Video Card: RTX 2060
sound_card: on board
Hard_Drive_Capacity: 6.5TB
Monitor/Display Make & Model: Iiyama 27"
Re: Can it be done?
Post by flagpole »
So i split the channels into RGB and used the blue channel to create a mask layer.
Often a good idea if you are trying to separate out something that is predominately one colour. in this case green.
Adjusted the contrast so i basically had a silhouette
Then i loaded it as a new mask layer
(Click the image below to view the transparency)
and put in a new background
It's important to realise that there is not just one technique. It depends on the image.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Re: Can it be done?
Post by hartpaul »
You will find a tutorial on a similar removal of background here:
http://people.vts.su.ac.rs/~pmiki/Racla ... 0Masks.htm
RobertdB
Re: Can it be done?
Post by RobertdB »
Wow!! Amazing work Flagpole :-) Thanks :-D
RobertdB
Re: Can it be done?
Post by RobertdB »
hartpaul wrote:You will find a tutorial on a similar removal of background here:
Thanks hartpaul!! very useful :-D
