Can PSP 2018 straighten spine curvature of a book scan
AlanLaughton
motherboard: Asus TUF Z270 Mark 2
processor: Intel i7-7700K
Video Card: nVidia GTX650
sound_card: built in
Hard_Drive_Capacity: 6.5TB
Monitor/Display Make & Model: 28" LG
Corel programs: Paintshop Pro 2018
Post by AlanLaughton »
I've recently received photographs of each page of a magazine that was not able to be scanned because the pages were not able to be flattened out due to its hard spine. As a result, each pic has the text curved into the centre spine. I can straighten the overall text with the "Perspective Correction tool" but I have no idea if any tool or action can the flatten the text out to a normal flat page. Is this possible? Some very expensive professional scanners software can do it, but is it possible in PSP 2018 ? Any help or suggestions appreciated.
Thanks,
Alan
flagpole
motherboard: Gigabyte B450 AORUS ELITE DDR4 USB 3.1 RGB
processor: Ryzen 2600
Video Card: RTX 2060
sound_card: on board
Monitor/Display Make & Model: Iiyama 27"
Re: Can PSP 2018 straighten spine curvature of a book scan
Post by flagpole »
Mesh warp?
I guess all the pages will be warped the same.
AlanLaughton
Not all the pages are the same. The left side pages curves to the right at the centre spine and the the right pages to the left. Also as each page was photographed manually from different angles and distances, so they all differ slightly.
AlanLaughton
I had a play with the Warp Mesh Tool. I can straighten out part of the edge but there is no spot to pull from in the corners. Is there another option ?
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
With the mesh warp, if you need to move the corners, you may need to expand the canvas size so that the nodes that act on the page are farther away from the corners as the corners do not move. As well as increasing the number of points for finer grain control.
There is a script for GIMP that is meant to be used for things like this. What it does is it has you create two paths that follow the curve of the page. Then it perform a curve distortion to try and unbend the image. Don't know how well it works though.
http://registry.gimp.org/node/19214
DaveQ
motherboard: Acer Aspire Ethos 8950G
processor: Intel Core i7 2630QM
ram: 16Gb DDR3
Video Card: AMD Radeon HD 6850M 2Gb DDR5
sound_card: Creative Labs 5.1 Surround Sound
Hard_Drive_Capacity: SSD 1Tb
Monitor/Display Make & Model: Acer 18.4" HD+ LED clear.fi
Corel programs: PSP X9, 2018 64-bit. AFS Pro 3
Post by DaveQ »
In the absence of any really suitable tool in PSP, you could take a look at DxO ViewPoint. I take images of artworks for Art Galleries. These are mounted on the walls of the galleries, and cannot be taken down, so I have to photograph each at different angles depending on the placement of the object. I then use ViewPoint to correct the distortion, text, etc.
Download a free trial from https://www.dxo.com/us/photography/phot ... -viewpoint and give it a go.
