PSP X9 - Manipulating Vector Text
mus
processor: Intel i7 7700
ram: 16Gb
Video Card: NVidia
Hard_Drive_Capacity: 2.25Tb
Monitor/Display Make & Model: AOC x2
Corel programs: PSP X9
Post by mus »
I have created several vector layers with circles and squares and can happily move/resize these.
When I create a Vector Layer with text it seems that I cannot move their position on the image or rotate/edit them etc. Are they locked somehow?
Very frustrating.
Many thanks!
Mus
Radim
ram: 4GB
Monitor/Display Make & Model: 27 inch
Re: PSP X9 - Manipulating Vector Text
Post by Radim »
Do you have selected a proper layer?
Some screen shot of work area would be helpfull..
mus
ram: 16Gb
Video Card: NVidia
Post by mus »
Hi Radim,
Yes, layer selected. And the text on the image itself.
See attached .png if it uploads correctly.
The 'Text Area' text seems to be locked and unable to be moved.
I copied it and was able to move it to create the '.org' text OK.
The text can't be rotated - I'd like to be able to use a particular font and angle it upwards from left to right.
Also if I try to edit it how do I apply the change and all sorts of things are happening like the text starts going backwards as I type :-(
Many Thanks!
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
Please crop the image so that we see only a quarter of the circle and the Layers palette is shown about twice as large. It is difficult to read the layers to see what they are labelled and where the text is.
ie eliminate the excess and show only what is important. We don't need to see all the tools on the left of the screen.
mus
ram: 16Gb
Video Card: NVidia
Post by mus »
Thanks!
Any better?
M
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Alright this is a guess, but I think you might be experiencing text wrapping.
So with text if you click on top of another vector shape, as it appears you have, the text will either enter into Text Wrapping mode where the shape acts kind of like a text box. Limiting the text to that area. Or it'll enter text on a path mode. This will have the text following the path of the object, essentially attached directly to the object.
In both cases, moving, rotating, do not work. You need to create a new text object making sure to hold ALT when creating it so that it doesn't attach itself to another vector.
Here is a video demonstration of the issue: https://drive.google.com/file/d/0B8FlFL ... ZpYzA/view
flagpole
motherboard: Gigabyte B450 AORUS ELITE DDR4 USB 3.1 RGB
processor: Ryzen 2600
Video Card: RTX 2060
sound_card: on board
Hard_Drive_Capacity: 6.5TB
Monitor/Display Make & Model: Iiyama 27"
Post by flagpole »
Very interesting Levi
mus
ram: 16Gb
Video Card: NVidia
Post by mus »
LeviFiction wrote:Alright this is a guess, but I think you might be experiencing text wrapping.
Many thanks Levi. Perfect solution and solved a lot of frustration :-)
Best
M
jcrous
motherboard: Lenovo X220
processor: Intel I5 2450M at 2.5 GHz
ram: 8 MB
Video Card: on-board
sound_card: on-board
Hard_Drive_Capacity: 500Gb
Monitor/Display Make & Model: Lenovoo X220
Corel programs: 7, 8, X1, X6, X8, PSP 2018 Ult.
Post by jcrous »
I am on the right track. It just didn't work.
I then noticed some of the outer text on both sides were missing, so I adjusted the kernel to zero and it is perfectly justified on both sides in the rectangle.
In the past I always worked with text as floating, on a raster layer. Now it is a vector and I don't get the white background transparent. I want to write the books blurp in colour, over the background image, as a seperate layer. Here I can't figure it out.
In the interim I jump between Photoshop and PSP, but it is some effort. I would lije to work in PSP only.
Johan Crous
Storieman / Story Man
www.johancroys.co.za
