It broke, and I cannot find the solution.
When you have a large object selected and apply the tool, such that
1. the inner node is White and outter node is black,
2. the tool is radial or elliptical, then
the resulting Image is a smaller object with the Center of the radial with Alpha.
The object is smaller and makes this tool unsuable. It does not retain the object original size.
e.g. DO NOT CHANGE the object. Simply cut out the radial with Alpha.
Side Note, if you do
3. the inner node is BLACK and outter node is WHITE,
The Tools works OK. The Alpha is at the edge, and the Object is retained at the Center of the radial.
Making it smaller.
The fix I had a Long time ago set somekind of Default mask.
I have no idea how to do this, they recommended Setting a value of 10,000.
How can I fix the tool so that the object is retained and not cropped when configured using 1&2.
Thanks - This Problem is hard to explain. I hope it is clear.
