Pictures losing significant detail when rendered as a video
Sine Nomine
motherboard: Gigabyte Technology Co Ltd Z68X-UD3H-B3
processor: 3.10 gigahertz Intel Core i5-2400
Video Card: AMD Radeon HD 5700 Series
sound_card: ASUS Xonar D2X Audio Device
Hard_Drive_Capacity: 3TB
Monitor/Display Make & Model: Samsung S27C570
Corel programs: Corel Video Studio Ultimate
Post by Sine Nomine »
I am trying to make a video using a very long picture, like a long panorama, and cause the video to pan from one end to another. The source picture is of reasonable quality and when zoomed shows relatively fine detail.
This is the source picture at this link
https://image.ibb.co/bJNiMG/Example.jpg
You can zoom in on it to verify that it is reasonable quality
and this is the result after making a 1920 x 1080 30fps as played in a video player is this link
https://image.ibb.co/eycHgG/Video_Studio001.png
The lack of detail is not in the original picture, It seems VideoStudio (v10) is stripping or optimising the picture inside the program, and I can't see anywhere to reduce or switch it of.
All I want to do is to pan from one end of the image to the other. This is experimental, if I can get it operational, I will want to do longer images.
Thanks for any pointers you can show me.
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Re: Pictures losing significant detail when rendered as a vi
Post by asik1 »
Interesting ,
Looks as that image is beyond VS limit.
I halved the image it was better but still not fine
So I halved the half and it was much better now.
So 4 quarters will be the first workaround option.
Panasonic X900m, VXF1
Unfortunately the program uses a project having say 1920 x 1080 for a HD video.
Adding an image can only display 1920 x 1080, that effectively strips the original image of pixels.
If you were to cut your image into sections at 1920 x 1080 each would display in full, well! as good as images get. That is what asik is basically doing, but would use 14 images, your original is very long.
However I tried using Customise Motion with reasonable results.
Place the image on the overlay track so the whole image is in view.
Set its duration to 30 seconds ish
Right click the clip and choose Customise Motion
Set Size to 400
Set position for keyframe 1 to 500
Right click Keyframe 1 (the red one) for Copy to all
Select keyframe 2 (to the right)
Set position to -500 (simply add a - minus symbol
Play the effect.
I also set a pause of 2 sec for each full screen
Attached is a VSP, you will have to re-link to your image file “Example.jpg”
music.zip
opens using X10.5
(1.52 KiB) Downloaded 185 times
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Hard_Drive_Capacity: 1TB
Post by tletter »
Sine Nomine wrote:The lack of detail is not in the original picture, It seems VideoStudio (v10) is stripping or optimising the picture inside the program, and I can't see anywhere to reduce or switch it of.
This is a known issue with VS, see http://forum.corel.com/EN/viewtopic.php?f=1&t=60291 which includes the workaround that I was forced to use.
Sine Nomine
Thank you Trevor for your very helpful file. Thank you also everyone else, you have all been very helpful. I have a few ideas to work. There is light at the end of the tunnel.
Thank you.
