combine video and picture
vasilis
sound_card: nvidia GTX 2060
Hard_Drive_Capacity: 500 gb
Monitor/Display Make & Model: ASUS G731GV
Corel programs: VS 2020
Post by vasilis »
hello i w onder if i can combine videos and pictures.i mean to use a static picture together with video in VSX10
Re: combine video and picture
Yes. You simply place the picture in the timeline in the place you want it to appear. It can be before, after or between video clips. You can right click the photo and set its duration, or simply highlight it and drag out the yellow bar at the right end of the photo till it is as long as you wish. And if you just want the photo to overlay video, then place the photo in an overlay track where you want it to appear.
vasilis
Post by vasilis »
no i mean merge video and picture.the picture to be appeared like a part of background.how can i say..the video appears above the picture.overlay the picture.To be used picture like canvas.i want to create a text using text effects ''on'' a picture.not in the classic black window display of VS...I hope understnd what i mean....i attach a file
Capture_1 - 1.7z
(158.12 KiB) Downloaded 120 times
BJC
Hard_Drive_Capacity: 1TB
Corel programs: Videostudio X10 and 2020
Post by BJC »
Yes - what you want to do is called "Picture-in-Picture" (PiP) altho both items may / can be a video
put the video in the top video timeline and your picture in the overlay track under it and change it's size to your requirements
vasilis
Post by vasilis »
ok i w ill try,but should i drag the picture first?i want my static picture to be my background and ''write'' on it
BJC
Post by BJC »
then put the picture in the top track and the video in the overlay track
what do you want to 'drag' the picture for
just try what my picture shows
try these things and you will see and learn
Terfyn
motherboard: ASUSTeK P8H61-MX
processor: Intel Corei5-2320
ram: 8Gb
Video Card: NVIDIA GeForce 210
sound_card: NVIDIA High Def Audio
Hard_Drive_Capacity: 1000 Gb
Monitor/Display Make & Model: Acer & LG
Corel programs: VS X10 and PSP X8
Post by Terfyn »
I would suggest you put the picture in the top timeline and the video in the first overlay line. Use the transparency slide to vary the intensity of the video and the square to locate the video.
"Picture in picture" will put a frame into the picture which you may not want.
I use this method to produce "ghost" effects.
vasilis
Post by vasilis »
ok thank you both of you.i will try with patience
