combine two videos
vasilis
- sound_card: nvidia GTX 2060
- Hard_Drive_Capacity: 500 gb
- Monitor/Display Make & Model: ASUS G731GV
- Corel programs: VS 2020
combine two videos
hello i have two video clips.and i want to combine-merge to one.i want after ending the first to begin the second clip with a natural sequence.how can i do that?sorry for my abd english and i hope to understand what i wand to say.also with video studio's live screen capture tool can we recorde and images or only videos?
BJC
- Hard_Drive_Capacity: 1TB
- Corel programs: Videostudio X10 and 2020
Re: combine two videos
That is the most basic function of videostudio, it is what videostudio was first made to do, to combine and/or cut clips
Simply put the two video clips in the top timeline in the order you want them , just two if that is what you currently want but can be any number
Then go to "Share" and choose to create a video file, this will produce one video of the two originals together
vasilis
Οκ but i want to do with smooth sequence
BJC
that is what you will get
what EXACTLY do you want
you can out a transition across the join to blend from the first to the second
vasilis
ok i don't know very much about that.i read the guide.how works the transition?can i find any tutorial?
BJC
How long have you been using videostudio now, quite a few years, have you never used transitions, what do you use videostudio for
vasilis
for inserting subs .
BJC
when the two videos are in the timeline choose a transition from the transition library and drag it down across the join between the two videos
Watch this video https://www.youtube.com/watch?v=fk5_2Ncj9eI
There are many useful videos on Youtube search for 'Videostudio'
you must experiment more with your programs . Try things and see what happens , you will not damage anything by trying different things
Forget guides and tutorials for a while until you need to do complicated things then a guide/tutorial can be useful but teach yourself basics first , think to yourself "What if" what will happen if I do this or what happens when I do that
if you get in a mess just close Videostudio / Photoplus without saving anything and all your mistakes will vanish
the best way to learn is to find out how to do it yourself
hover the mouse cursor over most items onscreen and a "Mousetip" will explain what it does
