ASP 3 Pro Lens Profile - Olympus M.Zuiko ED 14-150 F4.0-5.6
Tips, Tricks, and Results
georgejkw
operating_system: Linux
System_Drive: O
Post by georgejkw »
I have created a lens profile file for Aftershot 3 Pro that contains lens information for this lens, based on the information in this post.
http://forum.corel.com/EN/viewtopic.php?f=95&t=47110
The attached file replaces lens-db.xml in the AS program/supportfiles/Profiles/LensProfiles directory (eg Linux /opt/Aftershot3(64-bit)/supportfiles/Profiles/LensProfiles). Please make a backup of the original before you use this, just in case!
Note that the lens name in this file has been changed to Zuiko Digital ED 14-150 F4.0-5.6 because this is how AS identifies the lens (even for the version II lens I have)
I found that I have to click the Reload EXIF button under lens correction to get Enable correction to apply.
HTH
lens-db.zip
(56.62 KiB) Downloaded 576 times
georgejkw
System_Drive: O
Re: ASP 3 Pro Lens Profile - Olympus M.Zuiko ED 14-150 F4.0-
Post by georgejkw »
Update
If you update to a new version, the modified file gets overwritten.
Replace this section in lens-db.xml
Code: Select all
<Lens raw="true" skip="false">
  <Model>M.Zuiko Digital ED 14-150mm f/4.0-5.6</Model>
  <Mount>micro43</Mount>
  <FocalLength max="150" min="14"/>
  <Aperture>4</Aperture>
  <CropMultiplier>2</CropMultiplier>
  <Converter factor="1" detected="false"/>
  <CorrectionCoefficients>
   <RadialDistortion a="0" b="0" c="0" focal="14"/>
   <RadialDistortion a="0" b="0" c="0" focal="150"/>
  </CorrectionCoefficients>
 </Lens>
with
Code: Select all
  <Model>Zuiko Digital ED 14-150mm f/4.0-5.6</Model>
   <RadialDistortion a="0.007060" b="-0.014860" c="-0.071190" focal="14"/>
   <RadialDistortion a="0.001770" b="-0.018200" c="-0.005490" focal="18"/>
   <RadialDistortion a="0.007470" b="-0.033400" c="0.032420" focal="25"/>
   <RadialDistortion a="0.001830" b="-0.009250" c="0.011890" focal="32"/>
   <RadialDistortion a="0.008900" b="-0.031390" c="0.062350" focal="49"/>
   <RadialDistortion a="0" b="0" c="0" focal="70"/>
   <RadialDistortion a="0" b="0" c="0" focal="95"/>
   <RadialDistortion a="0" b="0" c="0" focal="140"/>
 </Lens>
