I have 24inch monitor 16:10 (1920x1200 pixels) and I found a little hard to organize palettes I use to maximize workspace.
So wat is your solution of this?
I tried PSP 2018, but I am not happy with result: https://i.imgur.com/D0N4rCR.png
Bigger monitor resolution? 2560x1440
How you organize palettes in Edit mode of recent PaintShop?
TimW
- motherboard: ASUS M5A99FX
- processor: AMD FX8350 8 core 4.0GHZ
- Video Card: AMD Radeon HD 6900 Series
- sound_card: On Board
- Hard_Drive_Capacity: 256GB SSD
- Monitor/Display Make & Model: Dell UltraSharp U2412M 24"
- Corel programs: PSP X8, Knockout 2
Re: How you organize palettes in Edit mode of recent PaintSh
Personally, I keep all Palettes turned off until I need to use one. Too much clutter if I'm not actually using them. If I'm using, say, Layers & Materials - those are the only two I have active. I usually slide them somewhere over along the right side - no docking & turn them off when done. This is my own personal way of dealing with palettes & I suspect everyone does it a bit differently.
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
Similar to Tim, except I always have the Layers palette visible because I always start by promoting the background layer and duplicating it so I'm always using layers to some extent. And I keep them resized horizontally as narrow as possible while still being able to see the important stuff I'll need in the palette. For example, the Layers palette doesn't usually need to be very wide for my purposes. I don't see why you would normally need the script output palette visible as per your image so you could just close it. And unless you really need all of those color swatches showing in your Materials palette you can resize it both horizontally and vertically and then move the Layers palette underneath it, which is what I do. Those are the only 2 palettes I usually keep open.
JoeB
Using PSP 2019 64bit
JoeB
Radim
- ram: 4GB
- Monitor/Display Make & Model: 27 inch
Can a Scripts toolbar be blended nicely with others - let's say in line with standard toolbar? Or only as a separate "row/line"?
MarkZ
- motherboard: Intel DQ67SW desktop
- processor: Intel Core i7 i7-2600 3.40 GHz
- ram: 8 GB
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: LG Flatron E2241
- Corel programs: PSP 2018 X9 X8 X7 X6 ASP3 ASP
I make some of my palettes auto-hide so that they appear as a tab but can be accessed quickly. I have a smaller monitor and this works well for me. I have Organizer, History, Learning Center, Mixer and Brush Variance on auto-hide.
Mark
JoeB
- ram: 8 GB
If you mean the toolbar shown in my attachment, then yes. I have it up along with the other items on the Standard (albeit modified) toolbar. But you can also drag it off of there and have it separate (e.g., by itself below the regular toolbar.)Radim wrote:Can a Scripts toolbar be blended nicely with others - let's say in line with standard toolbar? Or only as a separate "row/line"?
JoeB
JoeB
