WinDVD Pro 12 - Gray window when trying to start
Moderator: lata
mmr
Post by mmr »
Hi.
When i try to run WinDVD Pro 12 i get a gray window up - as if its trying to open a new menu.
this is a newly installation.
tried on multiple machines - even freshly installed machines.
Anyone have seen this issue ?
Re: WinDVD Pro 12 - Gray window when trying to start
And welcome to the forums
I have WinDVD Pro11, that starts without problems.
I wonder if the program is trying to connect to the internet to show updates or advertisements.
If there is a problem with the server could cause problems.
Can you try disconnecting the internet then try running the program.
If the problem persists you should contact Corel Support, maybe try their Chat Line.
c26hulby
motherboard: gigabyte
processor: amd
ram: 8 gb
Hard_Drive_Capacity: 3000
Monitor/Display Make & Model: philips
Corel programs: roxio nxt 6 pro
Post by c26hulby »
I have same problem.
Roxio creator nxt 6 pro.
mmr
Post by mmr »
I had a ticket open with Corel.
Basicly they feked up.
In my case it is because of language - their product works if its English language windows and location.
I have Danish language and location.
see this msg from them.
Thank you for contacting Corel Technical Support.
I was informed that your issue is a known issue with WinDVD pro 12. It seems you are on a country outside US.
Please do not hesitate to contact us with any further questions.
They said that their developers are working on it but i doubt it.
Because i found out that i when you install it on an english windows it populates all the needed folders.
danish language are missing some .html files.
so i copied around and then i got it to semi work.
still have 1 box that i need to klik on every time i start WinDVD before the main program starts.
mhn1365
System_Drive: B
Post by mhn1365 »
me too :| :|
