In my install of PSP 2018 the clone brush does not work as it did. Instead of covering what I don't want with what I do want it covers what I don't want with a pattern of vertical lines. The settings are exactly the same as on my installation of PSP X9.
And what is the overlay supposed to do? Or where is it supposed to do it? It seems to make no difference if it is selected or not.
Any thoughts?
PSP 2018 - strange response from the clone brush
narrowgauge
- motherboard: Asus PRIME X370-PRO
- processor: AMD Ryzen 5 1400
- ram: 32GB
- Video Card: Nvidia GTX750 Ti x 2
- Hard_Drive_Capacity: 6 Tb
- Monitor/Display Make & Model: iiyama Prolite B2780HSU x 3; B2480HSU x 1
- Corel programs: PSP 2018
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
Re: PSP 2018 - strange response from the clone brush
Are you working on the background layer ?
Try to duplicate it as new layer and work on the duplicated.
Or perhaps are you working on an adjustment layer ?
narrowgauge
- ram: 32GB
Yes, I was, a greyscale photograph. But then found I did not have the problem with colour images, and I that could use the tool correctly once I had converted the greyscale photograph to a raster image. I had not come across that before.Jean-Luc wrote:Are you working on the background layer?
Thanks for your answer.
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
For clarification, unless your image was originally a vector image it was already a raster(bitmap) image. I assume you mean once you promoted the Background layer (which is already a raster image layer without transparency named Background) you were able to work with it properly. When you promote the background layer the default name applied by PSP is Raster 1, and new added layers are named Raster 2, Raster 3, etc. That's simply to differentiate them from vector layers, which by default are named Vector 1, Vector 2, etc. when they are created. You can rename any layer to any name you want to make them easier to identify for you.narrowgauge wrote:Yes, I was, a greyscale photograph. But then found I did not have the problem with colour images, and I that could use the tool correctly once I had converted the greyscale photograph to a raster image. I had not come across that before.Jean-Luc wrote:Are you working on the background layer?
JoeB
Using PSP 2019 64bit
JoeB
andrewch59
Ok! I have read the previous posts and have no idea what a raster or vector layer is...I am just trying to clean up my photos taken with an 1800s camera. I then scan them into tiff files and put them on PSP for cleaning up. Since upgrading to the new 2018 program I am getting barcode or vertical lines when trying to clone out scratches, please help or can I go back to my fairly dependable 9 ultimate version.
rogerrenfrow
- motherboard: Asus Republic of Gamers
- processor: Core i7-3630QM
- ram: 8.148 GB
- Video Card: GeForce GTX 670MX
- Hard_Drive_Capacity: 428GB open
- Monitor/Display Make & Model: Asus default
- Corel programs: Paint Shop Pro X5, X6, X9, 2018
I'm having the same problem (at least it sounds like it) with the clone tool. On background layers and promoted background raster layers.
I've fiddled with the settings, and it doesn't seem to make much of a change in the result.
Jean-Luc
It is definitively a bug.andrewch59 wrote: Since upgrading to the new 2018 program I am getting barcode or vertical lines when trying to clone out scratches,
What you can do is Increase Color Depth to RGB 8 bit, make your cleaning and revert back to greysacle after the job.
- hartpaul
- ram: 8 Gb
This appears to be a bug introduced in PSP2018. In past versions (I tested X7 and X9), converting an image to grey scale did not cause any problems with the clone brush.
In PSP2018 an image converted to grey scale (Image > Greyscale) results in problems when using the clone brush.
To get normal operation you must convert the image (Image > Increase color depth) to at least RGB 8 bits / channel to have the clone tool function normally.
On the Standard Palette use the first white on the chart - this removed all those lines for me. Hope it helps you!
