I do not know what is going on here but think the problem is with the actual video, maybe the videos attributes, clutching at straws.
Any conversion seems to retain the problem, unfortunately only shows when uploading to YouTube.
Ok
I used a program called Video to Jpeg to rip the video, each frame being converted to Jpeg
Then add all Jpegs to timeline and set duration to 1 frame.
Render that back to MTS
I can select to render to any frame rate, 59.94 would create the original, 29.97 will create a slow motion, plays for twice the original length at 39 seconds
https://youtu.be/ppgA3_CjYeU
The amount of water movement seems to be the problem for YouTube, playback from any video on my pc plays ok.
Having problems with 60fps MTS files. What to do?
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
Re: Having problems with 60fps MTS files. What to do?
your video is far from "Peaceful Stream" video vise.
Panasonic X900m, VXF1
- aljimenez
- motherboard: Dell Inc. A08 4.16.2014
- processor: IntelCore i7-4790 3.60GHz 4Cores 8 Logical Proc
- ram: 24GB
- sound_card: AMD High Definition Audio
- Hard_Drive_Capacity: 500SSD+2TB
- Monitor/Display Make & Model: Three monitors, all Dell brand, one 4K
- Corel programs: Visual Studio, Paintshop
Running water is well known to be difficult to compress. The only way to have high quality is to have very very high bitrates. In addition the camera in this video clip is moving/zooming/panning making the compression even worse. Youtube will never use the high bitrates that are needed for the highest quality.lata wrote:I just do not know why your video, the 000076 gives poor quality when uploaded to YT?
Certainly I can appreciate the quality problem you are having????
User for more than 10 years.
- jungleexplorer
- motherboard: Gigabyte GA-B460M DS3H AC V2-Y1
- processor: Intel Core i5-10400F
- ram: 16GB DDR4
- Video Card: Nvidia GTX 1660S Super
- Hard_Drive_Capacity: m2 SSD 1TB
- Monitor/Display Make & Model: ASUS VS248H-P 24" Full HD
- Corel programs: VS 2022: PSP 2023
The link you gave is dead. Did it turn out better?lata wrote:Hi
Ok
I'm sorry for my sins Jesus, please forgive me. https://sorryformysins.com
- jungleexplorer
- ram: 16GB DDR4
The subject of the video is a bird that is moving around. Yes, moving water is difficult, but I can give you many links to youtube videos of running water similar to my video that are perfect, or at least a 100 times better then the way my video turns out on youtube. So again, this is not a question of whether youtube can handle this, because it obviously can. The question is, why can't it handle my particular video clip, and what can I do about it?aljimenez wrote:Running water is well known to be difficult to compress. The only way to have high quality is to have very very high bitrates. In addition the camera in this video clip is moving/zooming/panning making the compression even worse. Youtube will never use the high bitrates that are needed for the highest quality.lata wrote:I just do not know why your video, the 000076 gives poor quality when uploaded to YT?
Apologies, try this link,
https://www.youtube.com/watch?v=ppgA3_CjYeU
or
do you think it looks better.
I have 7 samples uploaded to YT of various formats, all are pretty poor, this may be the best by slowing down playback?
or
- jungleexplorer
- ram: 16GB DDR4
Wow! You really have tried hard. I appreciate that very much. And like me, you have hit that brick wall where nothing seems to work. So far out of all the videos, your's and mine, I think the upscaled 2560 x 1440 video looks the best, but it does not look great. My main concern is that the Dipper be clear. Now it makes sense that youtube might have trouble with the moving water, but why degrade the bird as well? In the upscaled video, the Dipper looks the best with more fine detail retained from the original video. If you would, try upscaling Jpeg video to 2560 x 1440 and upload that so that the VP9 codec will be applied. Maybe that will do a better job.lata wrote:Hi
or
Ultimately, I think the problem boils down to my camera and the quality of the video itself. The Panasonic HC-V180 is a budget camcorder. It is very good for a budget camcorder, but it is still a budget camcorder. I think the original video is JUST good enough to appear clear, but has no wiggle room at all for any measure of compression and that is why I am having this problem. If this video had been shot with a much better camcorder like the Canon Vixia HF G20, I don't think I would be having this much of a problem. I could be totally wrong here, but I am just grasping at straws now.
