Thanks for the replies and help. I'll give more info here.
I downloaded the 2 .MP4 files from the video camera to my computer hard drive. I then just used Windows Explorer to burn each file to 2 separate DVD's. So it's just like I am archiving and saving data (I do have external hard drives which I use to archive). So, there is no STREAM folder or anything else, they are just files on the DVD.
#1 .mp4 - 2,680,100 KB
#2 .mp4 - 2,829,688 KB
total is 5,509,788 KB.
I get the fact that they both won't fit on 1 standard DVD. Why do I want to put the video on DVD? Because I want to give the footage to family members to play on their DVD players, and I want to be able to play on my DVD player. I have a combo DVD/DVR which I use for other purposes so I'm not willing to go to a Blue-Ray at this time. The .MP4 files just copied to a DVD will not play on my DVD player; they WILL play on my computer fine. They will not play on my DVD player just converted to MPEG-2 or any other format. I can convert them to MPEG-2 and put them on a memory stick and insert into the USB drive on the TV. But again, I want them to play on a DVD player.
Back to my original question. I get it that it's not magic, and to fit the video of both files on a one DVD using VideoStudio, it MUST downgrade the video somewhere. Or does it? That's what I don't know. The quality that I got from using VideoStudio was not very good, so I'm wondering if I missed some last step setting before I pressed the button for VS to start the burn. (I want to add that I really liked using VideoStudio to put titles etc. on the video, effects between scenes and things.)
I see on the DVD VS created that the actual video looks to be on .VOB files, but I don't recall choosing that format or indicating any desired quality. Or maybe I don't have the option to do any of that. That's what I'm asking!
Thanks,
FlyingVee
Ken Berry wrote:
Can you tell us which program you used to burn the MP4 files to a DVD? And can you also tell us whether you played that DVD back on a Blu-Ray player as opposed to an ordinary standard DVD player? When you look at the structure of that disk on Windows File Explorer, does it show a STREAM folder, or a Video_TS folder?
I ask because it sounds like you might have burnt that one mp4 on a blank DVD disk but burnt it as what is called either an AVCHD disk or hybrid disk. That is burning high definition mp4 (which is what AVCHD is) to a DVD disk but in high definition Blu-Ray format (which stores the video in a STREAM folder). Such disks have much higher quality than standard definition DVDs, but can only be played back on Blu-Ray players. Moreover, using default settings, you would normally only be able to burn about 20 to 25 minutes worth of such video onto a single layer DVD blank disk. Your saying that you could only fit one of your videos onto the disk seems to support my interpretation.
The problem is, as asik suggested, that for a standard definition normal DVD, you have to down-convert your high definition mp4 to standard definition mpeg-2. That is because the international DVD standard will only accept standard def mpeg-2 on a DVD. Your original mp4 probably has a bitrate of at least 16 or 18 Mbps or perhaps even higher. A higher bitrate means higher quality. But the international DVD standard says that it can only accept a total bitrate of both the video and audio of no more that 10 Mbps. Normally this means for the video, it can only have a bitrate of 8 Mbps, and this is of course half or less than half of the original bitrate, and thus half or less than half the original quality. But that bitrate will allow around an hour of video to be burnt to a single layer DVD in the best quality a DVD is capable of (which is not as good quality as you get on a Blu-Ray or hybrid disc.)
