ASP 2 and 3 worked well on the previous Debian version (8), but it cannot be installed in Debian 9.1 because it uses some packages that are not ready in the Debian 9 repository.
I get this message:
dpkg: dependency problems prevent configuration of aftershot3x64:
aftershot3x64 depends on libpng12-0; however:
Package libpng12-0 is not installed.
aftershot3x64 depends on libgstreamer0.10-0; however:
Package libgstreamer0.10-0 is not installed.
aftershot3x64 depends on libgstreamer-plugins-base0.10-0; however:
Package libgstreamer-plugins-base0.10-0 is not installed.
Does somebody know how to make it work?
Can Corel fix ASP3 so it works on Debian 9?
Corel ASP 3.3 cannot be installed in Debian 9.1 (Linux)
TexJoachim
- System_Drive: Z
Re: Corel ASP 3.3 cannot be installed in Debian 9.1 (Linux)
I think I have a similar problem on openSUSE Tumbleweed: http://forum.corel.com/EN/viewtopic.php?f=94&t=62368
Please Corel, update AfterShot!
Code: Select all
sudo zypper install AfterShotPro3.rpm
[sudo] Passwort für root:
Repository-Daten werden geladen...
Installierte Pakete werden gelesen...
Paketabhängigkeiten werden aufgelöst...
Problem: libgstapp-0.10.so.0()(64bit) benötigt von AfterShotPro3-330234:3.3-0.234.x86_64 wird nirgends zur Verfügung gestellt
Lösung 1: AfterShotPro3-330234:3.3-0.234.x86_64 nicht installieren
Lösung 2: AfterShotPro3-330234:3.3-0.234.x86_64 durch Ignorieren einiger Abhängigkeiten brechenRe: Corel ASP 3.3 cannot be installed in Debian 9.1 (Linux)
I am on Ubuntu but got the dependencies by following the solutions in these links:
https://askubuntu.com/questions/840257/ ... ome/840268
https://support.rstudio.com/hc/en-us/co ... 04-Desktop
Apparently they are not included in the recent Debian distributions so we have to get them from previous releases.
TexJoachim
- System_Drive: Z
And this can be a problem: you don't mix packages from different versions of your distribution.
danbern
- System_Drive: N/A
- processor: Intel Core I5
- Video Card: Intel
- sound_card: Intel
- Hard_Drive_Capacity: 5TB
- Corel programs: ASP 3.4
Finally it works!!!
The new version 3.4.0.297 of CorelAfterShot Pro 3 works well with Debian 9.x and other distros based on Debian.
Better latter than never. Thank you Corel.
TexJoachim
- System_Drive: Z
It still doesn't work in openSUSE Tumbleweed.
