Mercalli problem
pepegota
- motherboard: ASUS TUF Z390-Plus
- processor: Intel i9 - 9900k
- ram: 64 GB
- Video Card: GTX 1660 6GB
- sound_card: On board sound
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: Ben Q, "21" LCD
- Corel programs: VS 2018, VS 2019, VS 2020
Mercalli problem
I cannot get rid of the "must be executed again" no matter what I do. It plays fine in VS but, when rendered, the Mercalli warning pops up. VS Pro X10
Re: Mercalli problem
There seem to be a few theories as to why this happens. They are reflected here: http://forum.corel.com/EN/viewtopic.php ... 67#p289167 You will see that my own theory is that after applying Mercalli, you have to use an output format (AVCHD?) which is progressive/frame based to avoid getting that message.
pepegota
- ram: 64 GB
I rendered at 1280 x 720, 60P from a 1920 x 1080 file. It did not work. I will try setting
the Project properties identical to the rendering file and see what happens as suggested. I will post the result. Nevertheless, this is a problem that Corel needs to address. Fortunately, I had Vegas to do the stabilizing.
I just rendered as suggested and no problem!
