User feedback, and script improvements are welcome.
I hope you find this useful.
Technique:
- Right-Click Background Layer > Duplicate
Right-Click Copy of Background Layer > Rename > Skin Blur
PSP Main Menu > Adjust > Add / Remove Noise > Median Filter > 13
NOTE: add prompt and suggest (12-15 pixels) could also also use guasian blur
PSP Main Menu > Edit > Copy
PSP Main Menu > Edit > Paste as New Image
PSP Main Menu > Image > Negative Image
Left-Click original image > De-select layer visibilty (click the eye) of skin blur
Left-Click negative image > Image Arithmetic
Image #1: original image
Image #2: negative image
Function: Add
Check On: All channels
Divisor: 2
Bias: 0
Copy Newly created grey image as layer on original image
Left-Click > Set Layer to Hard Light > 100
Right-Click > Rename > Skin Texture
Right-Click > Duplicate
Right-Click > Copy of Skin Texture > 65
Right-Click > Rename > Skin Texture Mask & Merge
Code: Select all
from PSPApp import *
def ScriptProperties():
return {
'Author': u'Joshua D. Meadows',
'Copyright': u'\u00A9 Joshua D. Meadows',
'Description': u'',
'Host': u'PaintShop Pro',
'Host Version': u'20.00'
def Do(Environment):
# EnableOptimizedScriptUndo
App.Do( Environment, 'EnableOptimizedScriptUndo', {
'GeneralSettings': {
'ExecutionMode': App.Constants.ExecutionMode.Default,
'AutoActionMode': App.Constants.AutoActionMode.Match,
'Version': ((20,0,0),1)
# LayerDuplicate
App.Do( Environment, 'LayerDuplicate', {
# Median
App.Do( Environment, 'Median', {
'Aperture': 13,
# Copy
App.Do( Environment, 'Copy', {
# PasteGraphicAsNewImage
App.Do( Environment, 'PasteGraphicAsNewImage', {
'CreateFromDropData': False,
# SelectDocument
App.Do( Environment, 'SelectDocument', {
'SelectedImage': 0,
'Strict': False,
# NegativeImage
App.Do( Environment, 'NegativeImage', {
# SelectDocument
'SelectedImage': -1,
'Strict': False,
# LayerSetVisibility
App.Do( Environment, 'LayerSetVisibility', {
'Command': App.Constants.ShowCommands.Hide,
'Path': None,
'WorkingMode': 1,
'ExecutionMode': App.Constants.ExecutionMode.Silent,
'AutoActionMode': App.Constants.AutoActionMode.Default,
# SelectDocument
'SelectedImage': 1,
'Strict': False,
# Arithmetic
App.Do( Environment, 'Arithmetic', {
'AllChannels': True,
'Bias': 0,
'Channel1': 0,
'Channel2': 0,
'ClipColorValues': True,
'Divisor': 2,
'Function': App.Constants.ArithmeticFunctions.Add,
'SourceImage1': -1,
'SourceImage2': 0,
# SelectDocument
'SelectedImage': 1,
'Strict': False,
# Copy
# SelectDocument
'SelectedImage': -2,
'Strict': False,
# PasteAsNewLayer
App.Do( Environment, 'PasteAsNewLayer', {
'InsertPos': -1,
# LayerDuplicate
# MultiObjectProperties
App.Do( Environment, 'MultiObjectProperties', {
'General': {
'Opacity': 75,
'Name': None,
'IsVisible': None,
'IsTransparencyLocked': None,
'LinkSet': None,
'UseHighlight': None,
'PaletteHighlightColor': None,
'GroupLink': None,
'BlendMode': None
'Effects': None,
'WorkingMode': 1,
'Path': None,
'AutoActionMode': App.Constants.AutoActionMode.AllAlways,
'General': {
'Opacity': 71,
'Name': None,
'IsVisible': None,
'LinkSet': None,
'GroupLink': None,
'BlendMode': None
'Effects': None,
'WorkingMode': 1,
'Path': None,
'General': {
'Opacity': 65,
'Name': None,
'IsVisible': None,
'LinkSet': None,
'GroupLink': None,
'BlendMode': None
'Effects': None,
'WorkingMode': 1,
'Path': None,
# Vector Selection Update
App.Do( Environment, 'VectorSelectionUpdate', {
'Path': (0,-1,[],False),
'Type': App.Constants.ObjectSelection.Select,
'Path': (0,1,[],False),
# Layer Properties
App.Do( Environment, 'LayerProperties', {
'General': {
'Opacity': None,
'Name': u'Skin Texture 65',
'IsVisible': None,
'LinkSet': None,
'GroupLink': None,
'BlendMode': None
'BlendRanges': None,
'Path': (0,0,[],False),
'ArtMediaTexture': None,
'Effects': None,
'BrightnessContrast': None,
'ChannelMixer': None,
'ColorBalance': None,
'CurveParams': None,
'HSL': None,
'Threshold': None,
'Levels': None,
'Posterize': None,
'Vibrancy': None,
'Overlay': None,
'LocalToneMapping': None,
'Invert': None,
'HistogramAdjustment': None,
'FillLightClarity': None,
# Layer Properties
'General': {
'Opacity': None,
'Name': u'Skin Texture 100',
'IsVisible': None,
'LinkSet': None,
'GroupLink': None,
'BlendMode': None
'Effects': None,
'HSL': None,
'Threshold': None,
'Levels': None,
'Posterize': None,
'Vibrancy': None,
'Overlay': None,
'Invert': None,
'General': {
'Opacity': None,
'Name': None,
'IsVisible': None,
'LinkSet': None,
'GroupLink': None,
'BlendMode': App.Constants.BlendMode.HardLight
'Effects': None,
'WorkingMode': 1,
'Path': None,
'General': {
'Opacity': None,
'Name': None,
'IsVisible': None,
'LinkSet': None,
'GroupLink': None,
'Effects': None,
'WorkingMode': 1,
'Path': None,
'Command': App.Constants.ShowCommands.Show,
'Path': (0,-2,[],False),
'WorkingMode': 0,
# SelectDocument
'SelectedImage': 1,
'Strict': False,
# FileClose
App.Do( Environment, 'FileClose', {
# SelectDocument
'SelectedImage': 0,
'Strict': False,
# FileClose
# SelectDocument
'SelectedImage': 0,
'Strict': False,
