Need to render a project(edited) again?
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
VSX9.20 min DVD.Due to various circumstances, after an initial viewing by others I will need to put background music on and most likely edit the video.The DVD will have some small audio files on it.What is the best way to do this.Can I save the project some where else before render and then do the necessary after the DVD has been authored, will I have to import the DVD into a new project or what.
BJC
Hard_Drive_Capacity: 1TB
Corel programs: Videostudio X10 and 2020
Re: Need to render a project(edited) again?
Post by BJC »
You can't change a physical DVD after it has been burnt, if it is not right just throw it away
open your original project and make the changes and burn a brand new DVD
Ken Veal
ram: 32 GB
Post by Ken Veal »
Is not the original project lost after rendering ?
Hi Ken
When did you last use the project, when you view Video Studio File menu there are 4 last used projects available at the bottom of the list.
A quick launch I suppose you could call it?
Does your project show there.
Ok
When you burnt the dvd did you first render your project to a mpeg2 video file, then used that to burn the dvd?
or did you burn from the project,
When you closed the burner module we are prompted to save the project, did you do that?
Hi Ken
You can import the files from the disc, read this tutorial
http://lata.me.uk/corel/importdvd/dvd.htm
If you are simply adding audio, no problem
If you are replacing audio, use scissors to cut and isolate sections, mute those sections, add audio.
Render the project to Same as First Clip.
Using that to burn a new DVD
BJC
Post by BJC »
Ken Veal wrote:Is not the original project lost after rendering ?
no the original .vsp file is always retained on your computer even after you render a video it can be reopened at any time
Ken Veal
ram: 32 GB
Post by Ken Veal »
I have not made the DVD yet,I was trying to pre emt the situation before authoring.
Hi Ken
I am confused
You have created a project and completed the editing.
You rendered the project to a mpeg2 video file
Your family viewed that video
Now you need to change the audio.
But you have lost the original project.
Is the above correct
You can edit the Mpeg2 video file by using the scissors to cut video into several clips, adding audio to your selections.
Render to Mpeg2 to create a new video.
Ken Veal
ram: 32 GB
Post by Ken Veal »
To clarify.
I am about to complete the project, it has not been rendered yet.When it is it will be to a mpeg2 file (as usual).I will not have the final say as to the final DVD contents.I am going to show an initial version to others (not family) who are a charity organisation.They asked to see a version of the DVD without any background music first( but it has some small audio files in it)After they view it they will pass judgement on what they want or do not want so there most likely be some editing to do before authoring another DVD.I posted because I thought it might be easier or better to know what to do before the initial render.I am not sure about how or whether a .vsp is saved after it has been rendered to a mpeg file.Sorry about the confusion
Ken Veal
ram: 32 GB
Post by Ken Veal »
When you elect to have the project saved on closing the burner module,does it go to your working folder, the default windows (7) video folder or some where of its own choosing
MrJohnny
motherboard: ASUSTeK COMPUTER INC. RAMPAGE V EXTREME
processor: 3.00 gigahertz Intel Core i7-5960X
ram: 32GB
Video Card: NVIDIA GeForce GTX 960
sound_card: onboard
Hard_Drive_Capacity: 8TB
Monitor/Display Make & Model: ASUS VH226
Corel programs: VS X5 Ult, VS X6 Ult, VS X9Ult,VS X10Ult
Post by MrJohnny »
Hi Ken
"When you elect to have the project saved on closing the burner module,does it go to your working folder, " - yes.
To be absolutely certain I would "Save as..." under the Edit tab, in a folder and different project (.vsp file) name of your choosing berore the burner module.
Then under the Share tab, rather than burn straight to disk, my preference is to create an ISO image then use a third party program to create the DVD. If you then burn this ISO image to a R/W DVD you can reuse the DVD as necessary. Saves wasting DVDs.
John
Terfyn
motherboard: ASUSTeK P8H61-MX
processor: Intel Corei5-2320
ram: 8Gb
Video Card: NVIDIA GeForce 210
sound_card: NVIDIA High Def Audio
Hard_Drive_Capacity: 1000 Gb
Monitor/Display Make & Model: Acer & LG
Corel programs: VS X10 and PSP X8
Post by Terfyn »
That is the great thing about video editing - you lose nothing.
The original video files always stay the same - you don't lose them.
Editing produces a .vsp file which is text - that will stay in your computer.
In Share it is best to create a mpeg-2 file for burning as a second stage - that will stay in your PC
Now what you can do is open the first edit (i.e. without music) Add the music and use the Save As to save a new .vsp file under a slightly different name. Example "Charity" for the original edit and "Charity with Music" for the modified edit with the music track added. You can use the original video files as often as you like and create different versions of the same video but do a Save As with a unique name for each edit you make. You only need to render in Share when your audience is happy with the result.
It is a better method to render to a mpeg-2 file and then burn your DVD from that file.
gewb
motherboard: MSI Pro B550-VC
processor: AMD Ryzen 7 5700X
Video Card: ASRock Radeon RX 6650 XT
Monitor/Display Make & Model: LG 24MK430
Corel programs: 2018, 2021, 2023 Ult.
Post by gewb »
Regardless, name the first project version as DRAFT_(name).
When starting the final editing phase, open the DRAFT project and SAVE AS the final published project name.
Edit, render and burn.
Get paid.
GEWB
