PSP 2018 doesn't install due to the EULA not accessible.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Re: PSP 2018 doesn't install due to the EULA not accessible.
Post by hartpaul »
I found something that has an effect. Windows 10 Pro 1607 Build 14393.1593
Right click Start > Control Panel > change to Category View > Appearance and Personalisation > Display and you get this:
I changed the Title Bar and Menus to 18 and ticked the Bold box and clicked Apply
This is what PSP2018 looked like :
Before change
After change
Unfortunately, that seems to have changed with Win 10 version 1703 (Creator's Update). This is the screen which is now available under Category view in Control Panel:
And as I said, Display is now under Win 10 Settings, and only allows scaling of everything on screen by percentage values. The Fonts entry only deals with selection of fonts and not their size.
josephlin
Alludo
motherboard: Intel Z490 chipset
processor: Intel Core i9-10900K
ram: 32GB
Video Card: nVidia RTX 2070S
sound_card: Realtek ALC892
Hard_Drive_Capacity: SSD 1TB
Post by josephlin »
Hi Jean-Luc,
Thank you for following up with this issue. What Ken's comment is my intention to know if the "DPI" setting will occur this display issue or not. Although we still cannot duplicate the issue after trying we expect to know if reset to 100% DPI can solve the issue.
BTW, it seems like you knew some people encounter this issue. If possible, would you mind ask them to offer more information? I've created a quick sheet for filling all information we need. You can share the below link with them.
https://docs.google.com/spreadsheets/d/ ... edit#gid=0
Hopefully, we can have more feedback from the user who met this issue soon. We are expecting to figure out the root cause ASAP. Thank you for your helping in advance.
Jean-Luc wrote:
josephlin wrote: As you can see the comment from "rondo", the EULA display may be caused by the DPI size. Could you help to check with the user who encountered this issue and get what DPI size they applied? Also, if their DPI size is higher than 100%, can you ask them to set DPI size down to 100% and give it a trying again?
Where are those settings in Windows 10 ?
Cheers
Joseph Lin
Sr. Program Manager,
Corel PaintShop Pro / AfterShot Pro / VideoStudio
ericlin-corel
Alludo
Corel programs: PSP
Post by ericlin-corel »
Hi, there
I used Win 10 version 1703 (Creator's Update) and had downloaded a tool "System Font Size Changer" to change my system font size to maximum/ minimum.
Issue not occurred.... Actually,no matter what my font size is, looks like the PSP installer's font size is not affected. (<---- Is this strange?)
The "Reset Internet Default" may work, it is in the "control panel \ classic view\ Network and Internet" page.
Thanks.
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
josephlin wrote:Hi Joseph
Yes.. but...
where to find the DPI settings in Windows 10 ?
Is the PSP version a clue ?
The user who has the problem has a different version, with a (b) :
Simone Corel UK
Alludo
Post by Simone Corel UK »
Hello Jean-Luc
We have indeed some users with similar issues which in my opinion are caused by certain settings in a system.
If Paulette has got a ticket number, I could check what went wrong in her case.
I have found the French forum's entry and I wonder in what application we are in Paulette's case.
If Paulette can only see the EULA window, is our frame that loads the different html pages, still there? Does the EULA window cover our frame?
Chapeau to Spirtfire to find that combination!
If Paulette or Spritfire press Alt+C, what is Alt+C for? I have set up a French Windows 10, but my Internet Explorer doesn't react to Alt+C.
I wonder what focus is deactivated by doing that, as Spitfire said.
If Paulette is in the EULA window, this is her browser, but if she has got several browsers as default, and the same combination helps, then it should be Windows.
Is it possible to ask Spitfire and Paulette to take screenshots of this part:
Quand la fenêtre "Paramètres" et "Options" apparaît, tu cliques sur l'onglet "Paramètres" (même s'il est sélectionné, c'est pour désactiver le focus) puis tu appuies sur Alt+I et l'installation devrait démarrer.
It would be a great help if we could solve that mystery.
On va essayer une méthode à l'aveugle.
- Quand la fenêtre "Contrat de licence" s'affiche. Appuie sur Atl+C puis Alt+S (le Alt à gauche du clavier, pas le Alt Gr). Tu devrais arriver à la deuxième fenêtre.
- Quand la fenêtre "Paramètres" et "Options" apparaît, tu cliques sur l'onglet "Paramètres" (même s'il est sélectionné, c'est pour désactiver le focus) puis tu appuies sur Alt+I et l'installation devrait démarrer.
Jean-Luc
Post by Jean-Luc »
Hello Simone,
will ask...
PS : just for info, what is the (b) in version number ?
josephlin
Alludo
ram: 32GB
Post by josephlin »
Hi Jean-Luc,
Good catch!! In fact, the (b) is a slightly updated version for solving a minor "localized string" issue in the layer palette. The build update is majorly for "Japan" marketing so you don't need to worry about that.
PS: It's our mistake since the (b) should not show up in the version number. Sorry for making confusion.
Jean-Luc wrote:Hello Simone,
will ask...
Cheers
Joseph Lin
Jean-Luc
Post by Jean-Luc »
josephlin wrote: PS: It's our mistake since the (b) should not show up in the version number. Sorry for making confusion.
Thank you Joseph. It is good when things are explained...
fischdl
System_Drive: D
motherboard: Dell G3
processor: I7-8750h
ram: 24gb
Video Card: Invidia GTX 1050ti
Hard_Drive_Capacity: 1tb
Corel programs: PSP
Post by fischdl »
It looks like this issue was never resolved. I am having this issue on my Dell G3 laptop. I changed the scalling with no sucess. How do I fix?
