PSP 2018 doesn't install due to the EULA not accessible.
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
I'm trying to help a French user.
She cannot install 2018 (buyed by Corel) because the screen where the EULA (CLUF in French) is displayed is out of screen and she cannot click on "Accept". (see attached)
She has tried :
- changing Windows text display percentage
- running as administrator
- installing the trial version
- and some other things
without luck.
She has contacted Corel but no response.
Does anybody has a suggestion ?
Kathy_9
Hard_Drive_Capacity: 2TB
Re: PSP 2018 doesn't install due to the EULA not accessible.
Post by Kathy_9 »
Can they click in that white box and use the down arrow or page down key?
Jean-Luc
Post by Jean-Luc »
Kathy_9 wrote:Can they click in that white box and use the down arrow or page down key?
Thank you Kathy,
will ask her ...
josephlin
Alludo
motherboard: Intel Z490 chipset
processor: Intel Core i9-10900K
ram: 32GB
Video Card: nVidia RTX 2070S
sound_card: Realtek ALC892
Hard_Drive_Capacity: SSD 1TB
Post by josephlin »
Hi Jean-Luc,
If possible, could you share the user's system configuration and the OS version for reference? It can help us to figure out the installation issue easily.
Cheers
Joseph Lin
Sr. Program Manager,
Corel PaintShop Pro / AfterShot Pro / VideoStudio
Jean-Luc
Post by Jean-Luc »
josephlin wrote:Hi Jean-Luc,
Hi Joseph,
will do it..
In the meantime, Spitfrog, administrator of the French forum, has found a solution, working only on the French version :
Alt+C
Alt+S
Click on "Parametres/Settings" tab
Alt+I
and installation starts...
Jean-Luc
Post by Jean-Luc »
josephlin wrote: If possible, could you share the user's system configuration and the OS version for reference?
She send me the attached...
informationspsp2018.pdf
(340.96 KiB) Downloaded 319 times
josephlin
Alludo
ram: 32GB
Post by josephlin »
Hi Jean-Luc,
Thank you for sharing. We cannot find any specific reason to cause this happen. Can you help to gather more info?
1. Does the user install PSP2018 into Desktop machine, NB or tablet (e.g.: Surface Pro)?
2. What PSP2018 version the does user install? Ultimate or Pro?
Cheers
Joseph Lin
Jean-Luc
Post by Jean-Luc »
Hi Joseph,
Here the missing informations :
She buyed Ultimate and installed on her :
- Asus notebook, Windows 10 version 1703
- desktop (tower, customized build)
Installation encountered the same problem on both PCs she solved with Spitfrog's solution.
She has a friend with Samsung laptop and Windows 10. She has the same installation problem with Ultimate.
It is perhaps related to the French version but I don't understand why, because other French users didn't have the same problem.
PS : If I understand you, there is a difference between version Ultimate and version Pro (you ask which version she installed). Could you be more explicit?
netgrafik
Post by netgrafik »
The error also occurs in other languages ​​...
See: http://forum.corel.com/EN/viewtopic.php?f=56&t=62164
ericlin-corel
Alludo
Corel programs: PSP
Post by ericlin-corel »
Hi, Jean-Luc
Could you also check the following information:
1. What web browser do the issued systems installed? (Ex: Edge, IE11, Chrome......etc.)
2. What is the default web browser on each issued system?
Thank you.
Eric Lin
Jean-Luc
Post by Jean-Luc »
ericlin-corel wrote:Hi, Jean-Luc
Thank you.
Eric Lin
Hi Eric, here the information...
The first person has :
1. Internet Explorer and Google Chrome installed
2. Internet Explorer set as default
The other person has :
1. Google Chrome, Internet Explorer and Firefox installed
2. Firefox set as default
Hope this helps,
Jean-Luc
rondo
motherboard: Gigabyte
processor: Intel I5 6600k 3.5 GHz
ram: 16 GB
Video Card: Nvidia 1060
sound_card: creative x-fi
Monitor/Display Make & Model: Asus ProArt
Corel programs: PSP X6, X9, Aftershot Pro 3, Painter
Post by rondo »
Appears to be a screen scaling issue in Windows. It needs turned down to get the entire EULA- changing the text won't help- change the size of items to 100% or less.
josephlin
Alludo
ram: 32GB
Post by josephlin »
Hi Jean-Luc,
As you can see the comment from "rondo", the EULA display may be caused by the DPI size. Could you help to check with the user who encountered this issue and get what DPI size they applied? Also, if their DPI size is higher than 100%, can you ask them to set DPI size down to 100% and give it a trying again?
One more thing that user can try is: Reset "Internet options" setting of IE and see if it can help this display problem.
Thank you.
Eric Lin
Hope this helps,
Jean-Luc
Cheers
Joseph Lin
Jean-Luc
Post by Jean-Luc »
josephlin wrote: As you can see the comment from "rondo", the EULA display may be caused by the DPI size. Could you help to check with the user who encountered this issue and get what DPI size they applied? Also, if their DPI size is higher than 100%, can you ask them to set DPI size down to 100% and give it a trying again?
Where are those settings in Windows 10 ?
I would be grateful too if someone could say where this can be controlled in Windows 10. I spent considerable time yesterday looking for it. Even Microsoft seemed to say go to Control Panel > Appearance and Personalisation (which only appears if you have Control Panel in Category view). But this no longer has a section on controlling font size. It may have disappeared in one of the Win 10 major updates e.g. Creator's update??
In Settings > System > Display, the only option is to change 'Scale and Layout' which includes a reference to fonts. But this does not have a specific control only over size of display fonts, but increases the whole scale used by the monitor to, say, 125% or 150%. However, it may still be what Joseph is referring to.
