Lost Titles
sekjr
- ram: 4GB
- Hard_Drive_Capacity: 150GB
- Monitor/Display Make & Model: Acer AL2216W
- Corel programs: Videostudio Pro X4
Lost Titles
I deleted the icons for Titles in the Lubrary that I wouldn't be using. Now I want some of them back. What file folder would I go to in Pro X4, to retrieve lost titles?
- jparnold
- motherboard: Gigabyte Z390 UD
- processor: Intel Pentium i7 9700 3dot6Ghz
- ram: 16GB DDR3
- Video Card: Gigabyte RTX2060 OC 6GB
- sound_card: Onboard Realtec ALC887
- Hard_Drive_Capacity: 2048Gb mix
- Monitor/Display Make & Model: Samsung S27C450B
- Corel programs: Videostudio X10, Paint Shop Pro 2018
Re: Lost Titles
Try going to Settings>Library Manager>Reset Library
John a
sekjr
- ram: 4GB
Re: Lost Titles
Thanks - but - that only restores what was remaining after previously deleting all the other icons..., and wipes clean all my Favorites in the Title Library!
If I want to 'Import Library', it wants me to browse for a folder, which gets me back to my original question... for Pro X9. I upgraded...
Also - here's a goodie:
They changed the look of the transitions in X9 - specifically - in the PEEL category. They all used to have the page turning in green! Now, in X9 - they are a dull gray! Can that be changed???
Can the PEEL category from X4 be imported to X9???
sekjr
- ram: 4GB
Re: Can't navigate...
sorry to bother you but I'm having a terrible time with this site.
I read the intructions on how to post a new topic that someone posted - the pdf version - but I get no such place to do that! on any page! so I can't post!
There is nothing in the upr left crnr as the instructions say!
I need answers to questions I have...
Re: Lost Titles
Hi Sekjr
And welcome to the forums.
Please be a little patient as your first two posts are monitored then approved by Admin or Moderators, this can take a while, a few hours at the most.
Once you have posted twice your posts should show without approval speeding up any replies you may get.
I will read your posts again to see if I have any advice I can give...........
sekjr
- ram: 4GB
Re: Lost Titles
THANKS TREVOR! Oh - and I figured out how to post. My bad...
Re: Lost Titles
We can change the colours of the peel Do you still need the transitions from X4? as I would think they are the same as x9
BJC
- Hard_Drive_Capacity: 1TB
- Corel programs: Videostudio X10 and 2020
Re: Lost Titles
What has transition color got to do with lost titles Lata
Re: Lost Titles
sekjr wrote: They changed the look of the transitions in X9 - specifically - in the PEEL category. They all used to have the page turning in green! Now, in X9 - they are a dull gray! Can that be changed???
Re: Lost Titles
This folder contains the transitions for X5, I do not have X4 installed but will have a similar folder.
C:\Program Files (x86)\Corel\Corel VideoStudio Pro X5\Vfx_plug
The same folder for X9 contains one more file TrkTrans.vfx otherwise they are identical.
No point in transferring those files, but if you do……
The only problem you may have in transferring the files would be X4 is 32 bit program whilst X9 is 64bit
Make a copy of the X9 Vfx_plug folder before replacing any files.
Personally I think you are wasting your time and may cause more problems than its worth.
sekjr
- ram: 4GB
Re: Lost Titles
I feel like a fool. I didn't think I could change the color of the transition. I didn't know there was OPTIONS available.
Thanks for being so tolerant...
Re: Lost Titles
Not a fool at all, so many small bits and pieces that can be overlooked.
Strange that I prefer the grey/silver look rather the green, I change the colour to match the clips.
I guess the green would work if using Chroma key to view the background, never tried that option?
sekjr
- ram: 4GB
Re: Lost Titles
I editing Asian temples, and the irridescent green is really appropriate...
no I haven't used that capability...
Thanks for your support...
Re: Lost Titles
Sekjr
I have a solution for you
After adding the Peel type transition, change the colour to Green.
Now right click the transition on the timeline and choose Add to Favourites
Although the library clip animates showing Grey, when added to the timeline will have a green colour.
If you use different colours we can re-name the library thumbnail within the Favourites folder
Simply click the name (barndoor etc.) type a new name (green barn door)
sekjr
- ram: 4GB
Re: Lost Titles
WOW!!!
THANKS!!!
BUT - one modification. In X9 you double-click on the name, then backspace the old name out...
Great tip!
THANKS!!!
Great tip!
