Minor Glitch in Layer Styles?
pdxrjt
- processor: Intel Core i7 - 4.2 GHz
- ram: 32 GB
- Video Card: NVIDIA GeForce GTX 1080
- Hard_Drive_Capacity: 10TB Int.
- Monitor/Display Make & Model: Acer 32 inch x2
- Corel programs: Paint Shop Pro 2018
I have created a layer with text. I am exploring various layer styles (bevel, inner glow etc.) It used to be I could check: Preview on Image and check and uncheck various effects. Now however, if I select bevel (for example), check Preview on Image, then uncheck bevel and try to check another style, nothing happens (usually doesn't even let me check it.) However, if I uncheck Preview, check a different layer, then recheck Preview, it works fine. Anyone else notice this behavior? TIA
Adverts for Corel products when you close PSP don't bother me.
Kathy_9
- Hard_Drive_Capacity: 2TB
Re: Minor Glitch in Layer Styles?
It's working okay for me on PSP 2018. I'm assuming that's what you are using because it shows on your profile. If you are using a different version let us know.
From past experience the Layers Palette can be unstable. Just the other day I lost all the icons on the layers Palette and even a reset of the menu through the customize menu didn't work. Finally I cleared the cache via File -> Preferences -> Reset Preferences and checking "Delete All Cache Files".
pdxrjt
- ram: 32 GB
Thanks for the idea. I tried Delete All Cache Files and that didn't help. Yes, I am using PSP2018. Ah well, not the end-all but would be nice if it worked. Hopefully they will iron it out.
