Moviefactory 3.5.
trying to burn DVD's of my home movies directly from my camcorder. My camcorder has built in USB with cable. I start the process and the message : No capture driver found. appears and process goes no further. where can I get this capture driver ?
Thanx
Error mesage : No capture driver found
maddrummer3301
You need to supply the make & model of your video camcorder.
Is it a DV tape or does it write to Mini-dvd disks directly.
Also, post if you have a firewire port on the camcorder.
If you do have a firewire port on the camcorder and one on the
computer connect the camcorder up using a firewire cable.
Usually 4 pin on the camcorder to 6 pin on a desktop computer or
4 pin if your using a laptop computer.
Do NOT connect both USB & Firewire to the computer together at the
sametime. You can damage the camcorder.
Make sure to have the camcorder OFF when connecting any cables.
MD
MD
