Problem with Plugins in PSP 2018
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Re: Problem with Plugins in PSP 2018
Post by hartpaul »
And just in case something is corrupted there the following shows what I have in my working version:
and
02PerfectlyClear SE v3.jpg (21.75 KiB) Viewed 13086 times
and
Quantus5
motherboard: Gigabyte
processor: Intel Core i7
Hard_Drive_Capacity: 300GB
Monitor/Display Make & Model: Asus
Corel programs: Wordperfect X7, PaintShop Pro X9
Post by Quantus5 »
Thanks Kathy, JoeB, and HartPaul,
Unfortunately still no dice. The PerfectlyClear installer does not have an uninstaller (and nothing in Control Panel remotely even close -- I think the installer just installs the plugins into PaintShop Pro). So I just went ahead and deleted the "Perfectly Clear SE v3" folder in the Plugins/EN directory, and then tried re-installing it using the installer. No error with the PerfectlyClear installer, but when I go into PaintShop Pro still same exact missing files error I got before.
The "PerfectlyClearSE.8bf" file does show up in the location HartPaul indicated, as shown, size is 4,182 KB.
On the plus side I also tried installing it on my laptop (Core i7, 8GB) and that worked fine. It works on my laptop.
Thanks for all the help -- other than uninstalling PaintShop Pro 2018 itself and doing a full re-install, does anyone have any more ideas? I feel the key to the issue is this 8bf file and some bug with the installer? Probably works most of the time, odd that it is failing on my Desktop. Is it some kind of licensing file?
Quantus5
Post by Quantus5 »
I resolved my install issue with PerfectlyClear, although not painless. ;-)
I completely uninstalled PSP 2018. I re-installed PSP 2018. I then installed PerfectlyClear.
PerfectlyClear now works. :-)
PerfectlyClear installer must gave glitched the first time I installed PerfectlyClear. Probably a combination of something unique to my desktop and some bug in the installer.
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
Glad you got it sorted out and thanks for posting your solution as it may help others.
Cassel
ram: 16Gb
Corel programs: PSP 8 (JASC) to PSP 2023
Post by Cassel »
There is a blog post exactly about MuRa's Meister here:
http://scrapbookcampus.com/2017/08/feat ... er-clouds/
It might help you as this particular plugin (like others) is not compatible "out of the box" with newer PSP versions.
Cassel
https://scrapbookcampus.com
zulabarr
Corel programs: Paintshop Pro 2018
Post by zulabarr »
I'm beyond frustrated with trying to get plugins to work in this version. I have no problems with PSP 9, and wish I had not upgraded. Plugins are important to me, and this version is buggy beyond belief. I have spent hours on this, with help from Corel. It should not be this complicated.
Kathy_9
Post by Kathy_9 »
If you are looking for assistance, it would help if you said whether you are using the 32-bit or 64-bit version of PSP2018 and specifically which plug-ins are not working, error message, etc.
rhiannyn
motherboard: ASUSTeK COMPUTER INC.
processor: Intel Core i5-6400 CPU 2.70GHz
ram: 8 GB
Hard_Drive_Capacity: 1144 GB
Corel programs: PSPx9, and PSP2018 Ultimate
Post by rhiannyn »
zulabarr wrote:I'm beyond frustrated with trying to get plugins to work in this version. I have no problems with PSP 9, and wish I had not upgraded. Plugins are important to me, and this version is buggy beyond belief. I have spent hours on this, with help from Corel. It should not be this complicated.
Exactly my issue. I can't even get my Topaz plugins into the program, let alone use them. So frustrating.
Also back and forth with emails to Corel trying to get it fixed. I am thinking of asking for a refund, and just going back to x9 (so glad I didn't delete it).
Tried everything they suggested, plus my own machinations added to the mix. Nothing. :/
You're right, it should not be this complicated.
As Kathy has already said to zulabarr, it would be extremely helpful if you could state whether you are using the 64 or 32 bit version of PSP when you are having problems. And apart from Topaz, what are the other plug-ins with which you are having problems?
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
It isn't complicated at all for most of us. Using the 32bit version of PSP2018 I have my file location for Topaz set to C:\Program Files(x86)\Topaz Labs and the plugins show up in Plugins and work just fine for me. I don't have Topaz in the 64bit version (if there is one) so can't say how well it would work in PSP2018 64bit.
JoeB
Using PSP 2019 64bit
Leslie
processor: intel core i7
ram: 32 gb
Video Card: intel iris
Monitor/Display Make & Model: Dell Inspiron 7700 27 All-in-One Desktop
Corel programs: 2019 Ultimate, 2022 Ultimate
Post by Leslie »
You may have to use the FM Patcher for a lot of the plugins. If not, the plugin will freeze your psp. I had to do that in X9, so they also work in 2018 because they are already patched.
http://www.filtermeister.com/fmpatcher/index.htm
VioletC
motherboard: Acer Aspire M3420 P0
processor: AMD A10 5700 APU 3.4 Ghz
ram: 16gb
Video Card: NVIDIA GeForge GTX 750 Ti
sound_card: NVIDIA
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Asus VC279 & Acer S240HL
Corel programs: PSP 7/X7/X9/2018, 2019, ASP 1/2/3...
Post by VioletC »
Here as well. WIndows 10, using the 32 bit PSP 2018. I have easily 200 plugins including Nik, they worked fine with versions 7, x7, x9 but are greyed out in 2018. Looks like the only ones working are MV's and Eye Candy 5.
VioletC
ram: 16gb
sound_card: NVIDIA
Post by VioletC »
Posted earlier today but I guess it hasn't been approved yet, so I'll try this one more time. I was also having problems with plugins in the 32-bit version of 2018, as I have hundreds of them and most were greyed out. Tonight I uninstalled PSP and re-installed, and they are all working now.
Correct, apologies for the delay, Admin
Cassel
ram: 16Gb
Post by Cassel »
Kathy_9 wrote:Not all plug-ins need to be imported into Filters Unlimited. Older Filter Factory plug-ins usually do. This should give you some guidance.
http://othpg.madness-inc2.com/impplgfu2/
Kathy, I am trying to import Harry's Filters into Filters Unlimited but I am still getting an error message that There is no file even though I have the file HarrysFilters4.8bf . I am trying to install it for the 32-bits version of my PSP2018 (even if I have a 64-bits machine). Is there something else I should do?
Cassel
JoeB
ram: 8 GB
Post by JoeB »
I'm not Kathy but does anything in this thread help?
http://forum.corel.com/EN/viewtopic.php ... 3&p=345467
JoeB
