Problem with Plugins in PSP 2018
Zantara
processor: i5-2100 3 10 Ghz
ram: 12Gb DDR4
Video Card: Intel UHD graphics 620
Hard_Drive_Capacity: 256SSD 1TB
Corel programs: From PSPX2 to PSP2022
Re: Problem with Plugins in PSP 2018
Post by Zantara »
MuRa doesn't seem to work as a stand alone plugin in Windows 10. One of these plugins that are just too old now. Filters Unlimited should work fine in your 32-bit version. And yes, you can import MuRa into FU.
You can import a lot of filters in FU:
AFS Import
AB Filters 2000
Alf’s Filters
Andrews Filters
Background Designers
Balder Olrik
Buttons & Frames
Color Effects
Color Filters
Color Rave
ColourWorks
CPK Designs
Crescent Moon
Cryptology
DC Layer
DC Special
David Blends
Deformations
Distortion Filters
Distort
Dominion
Ecosse
ECWS Filters
Edges
Effects
Enki’s Filters
Filter Attack
Filter Factory A-V
Frames
Funhouse Filters
Gradients
Graphic’s Plus
Greg’s Factory Output
GroanZone
Harry’s Filters
Horizonaus
I-Decay
Image Enhancement
It@lian Editors Filters
Jeux de Lignes
Johann’s Filters
Kang Filters
Krusty’s Filters
Kiwi’s Filters
L&K Site of Wonders
Layout Tools
Lens Effects
Lens Flares
Liquid Silk
Mac’s Curl
Master Blaster
Media Spark
Mirror Rave
MiscX
Mock
MuRa Seamless
Neology
Neu!
Nirvana
Noise Filters
Oliver’s Filters
Omphale Filters
Ormente Filters
Paper Backgrounds
Paper Textures
Pattern Generators
Penta.com
Photo Aging kit
Photo Kollers
Photo Tools
Pixelate
Plugins AB
Psychosis
Random Filter
RCS Filter Pack
Render
Sabercat
Sandflower
Saphire Filters
Screenworks
Scribe
Shape
Simple
Special Effects
Swap Shop
Sybia
Synthetic
Teph”s Trics
Texturize
Tile & Mirror
Toadies
Tools
Tormentia
Tramage
Transparency
Trond’s Filters
Tru Filters
Two Moon
Unplugged Filters
Variations
Video
Video Filter
Visual Manipulation
VM Filters
Sweeet
processor: Intel Core i7 6700 HQ 2.60 GHz
ram: 16 GB
Hard_Drive_Capacity: 1 TB
Corel programs: Paintshop Pro 2018
Post by Sweeet »
I appreciate your feedback/assistance...sooo I AM getting the error as you shared with the link about FU
"If the filters aren't valid filter factory plugins, you get this error and you have to move the filters from the temp folder into the PSP/plugins folder; but if they are valid, they will be added to the Filters Unlimited database. "
I did what they stated..copied those filters/plugins into the plugins folder of PSP (whether it was the 32 bit or 64 bit ..I saw two plugin folders for each version)...and it still gave me that above error (that is an older image I copied from that website, but the error reads the same)...
Jenna
Windows 10, 64 Bit
PSP 2018
Sweeet
ram: 16 GB
Post by Sweeet »
Sweeet wrote:I appreciate your feedback/assistance...sooo I AM getting the error as you shared with the link about FU
Oh and I failed to mention I also tried the FM patcher utility to see if that would help, ran it as administrator and it said something about it not being able to find the files or another...bah!
Jenna
Windows 10, 64 Bit
PSP 2018
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
Not all plug-ins need to be imported into Filters Unlimited. Older Filter Factory plug-ins usually do. This should give you some guidance.
http://othpg.madness-inc2.com/impplgfu2/
Kathy_9
Post by Kathy_9 »
Jenna - I just remembered that I had a similar problem with Mura filters. I did the same as you and ran them through FM Patcher and still no luck but I did find a patched version online that works for me.
You can find them here:
http://www.lismibaebi.com/FiltersandPlu ... ugins.html
Sweeet
ram: 16 GB
Post by Sweeet »
One last question, I HOPE *lol*....when I do import through FU, do I need to do it each time I need to use let's say a filter factory preset or are they already IN THERE after they're imported?
Jenna
Windows 10, 64 Bit
PSP 2018
Kathy_9
Post by Kathy_9 »
Once you import them, they are in there so you don't need to re-import each time you want to use them. By the way, the patched version of Mura filters I linked to above work fine in PSP 2018 without being imported into Filters Unlimited.
daveharney
Post by daveharney »
I installed PSP 2018 andthe Perfectly Clear that came with it. I see the Perfectly Clear files in the Corel plugins folder. How do I run Perfectly clear? Thanks.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
daveharney wrote:I installed PSP 2018 andthe Perfectly Clear that came with it. I see the Perfectly Clear files in the Corel plugins folder. How do I run Perfectly clear? Thanks.
Effects>Plugins>Athentech. Athentech is the name of the company that created Perfectly Clear.
JoeB
Using PSP 2019 64bit
daveharney
Got it - Thanks. Spent a lot of time in the help files searching for plugins or Perfectly clear with no joy. Should have asked you first!
JoeB
ram: 8 GB
Post by JoeB »
daveharney wrote:Got it - Thanks. Spent a lot of time in the help files searching for plugins or Perfectly clear with no joy. Should have asked you first!
I had the same problem the first time I installed Perfectly Clear. I ended up Googling for Perfectly Clear, which got me to the Athentech site, which was my hint to look for that in the Plugins list. :-)
JoeB
Quantus5
motherboard: Gigabyte
Hard_Drive_Capacity: 300GB
Monitor/Display Make & Model: Asus
Corel programs: Wordperfect X7, PaintShop Pro X9
Post by Quantus5 »
screenshot of PerfectlyClear greyed out.
I have a related issue. I have PaintShop Pro 2018 Ultimate (I installed the 64-bit version) on Windows 10 and installed PerfectlyClear.
The PerfectlyClear install says it was successful, However when I try to run this plug-in via: Effects --> Plugins --> Athentech Imaging --> PerfectlyClear SE v3...
The problem is that the "PerfectlyClear SE v3..." is greyed out and when I try to click on this greyed out menu choice nothing happens. :-(
I did check the plugins location that was described in an earlier post: Program Files --> Corel --> CorelPaintShop Pro (64-bit) --> Plugins --> EN
...and there is a PerfectlyClear SE v3 folder with a bunch of stuff in it. So it looks like it is installed, however the option to run the plug-in greyed-out, am I missing something?
Anyone know know what the problem is?
Quantus5
Post by Quantus5 »
I solved my problem with the "greyed out" PerfectlyClear menu choice.
My bad -- apparently you have to have an image loaded in the workspace -- then the PerfectlyClear plugin option is active (not greyed-out). It was greyed-out because I did not have an image loaded in the workspace.
However -- I then ran into another problem. When I select "PerfectlyClear" from the plugins menu I get the following error message.
Note: I've tried installing PerfectlyClear SE v3 -- three times... and every time it says the install is successful.
The error of course seems to indicate I'm missing some files, so the question is where do I get these missing files, or how am I able to do a complete install of PerfectlyClear?
Kathy_9
Post by Kathy_9 »
Maybe try an uninstall and reinstall of Perfectly Clear to see if that remedies the situation.
JoeB
ram: 8 GB
Post by JoeB »
Quantus5 wrote:However -- I then ran into another problem. When I select "PerfectlyClear" from the plugins menu I get the following error message.
You should check the Plugins folder for the Perfectly Clear sub folder and see if the PerfectlyClearSE.8bf file is actually there.
JoeB
