Installed MS3D on new Win 10 laptop, made sure that I installed as Administrator and installation was successful, launched OK (with the script error mentioned in a previous post)
However, every time when closing I get the Program has encountered an unspecified error and needs to close, and to send .dmp file to support.
I have noticed that the location of the .dmp file is incorrect, the actual files are located in a different location
Bearing in mind that the program is about 6 years old, help from Support will be non existent, any ideas as to what may be causing the error
Error When Closing
- RobertOZ
- Hard_Drive_Capacity: 7 TB
Error When Closing
You do not have the required permissions to view the files attached to this post.
- RobertOZ
Re: Error When Closing
Using the Win 10 Program Compatibility Troubleshooter, the report states that the program is incompatible
Hi Robert
I do not have that problem, the script error, yes that shows when accessing the internet via the Corel Guide – Home tab
But crashes no problems
Not sure if MC3D has a service pack available, have you tried checking for updates?
My version is 1.0.0.252
- RobertOZ
Thanks for looking Trevor, my version is the same as yours and there are no updates available, strange when you think about it, Corel launch a new program,then completely ignore it, no updates, no new releases for 6 years or more
FWIW I have the same version, and like Trevor I get no error msg when I close MS3D...
- RobertOZ
Still having issues, but for some reason do not get the error msg every time when closing, however, every time the program is closed 3 .dmp files are created, even when no error msg is given.
So could you please go to C:\Users\*******\AppData\Local and see if you have anything in the CrashDumps folder, because I get 3 files every time the program is closed
I have nothing relating to MS3D in the Crash Dumps folder, though I've opened and closed the program a few times in the past couple of weeks. Just did so again, but again nothing in Crash Dumps.
- RobertOZ
Thanks for checking Ken, wonder if this laptop being a 7th Generation Intel is just too much for MS3D
