"Save As" Preferences
PawleysDude
- Corel programs: PSPX9
When I open a jpeg file, edit it, and "Save As", my PSP X9 software is defaulting to pspimage format. Is it possible for me to change the default to jpg? I wandered thru the preferences menu but couldn't find anything that would let me do it. Thanks for your help.
Zantara
- processor: i5-2100 3 10 Ghz
- ram: 12Gb DDR4
- Video Card: Intel UHD graphics 620
- Hard_Drive_Capacity: 256SSD 1TB
- Corel programs: From PSPX2 to PSP2022
Re: "Save As" Preferences
I don't think so.
For that you have the option File > Export > JPEG-optimalisation
But if you use "Save as" jpeg is the next option under pspimage.
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Usually the Save As dialog will use your "last used" settings. For me X9 always defaults to JPG because it's what I last used. Then if I start saving as PNG automatically defaults to my last used PNG settings. Same with PSPImage.
Zantara
- ram: 12Gb DDR4
Ah! Thank you LeviFiction. You are such a brilliant source of knowledge and experience!
I only use the "Save as" to save a pspimage. Otherwise I use the File > Export option.
Shows what I know
Shows what I know
PawleysDude
Well, bummer. That's kinda what I expected but mine is not doing that. Regardless of how many files I open then Save As a jpg file, the next one always defaults to PSPimage. I searched for a "last used" option in Preferences, but no luck. Any suggestions? Thanks for your help.LeviFiction wrote:Usually the Save As dialog will use your "last used" settings. For me X9 always defaults to JPG because it's what I last used. Then if I start saving as PNG automatically defaults to my last used PNG settings. Same with PSPImage.
