PSP X9 crashes when trying to create a new image
wolverineinmich
ram: 12gb
Re: Work Around
Post by wolverineinmich »
While holding shift click FILE>NEW and it should work to open new file.
Leuvarus
Re: PSP X9 crashes when trying to create a new image
Post by Leuvarus »
This might be useful for the developers to mitigate the cause.
Gold Acres
processor: 2.00 gigahertz Intel Core2 Duo
ram: 4GB
Hard_Drive_Capacity: 3TB
Corel programs: X6, X7 & X8
Post by Gold Acres »
This is not a fix, but it is a good work around until it does get fixed.
Open a saved image
Promote the background to a layer and then delete that new layer.
Now you have a blank image that you can resize and work with.
Hi Guys
My program now seems to be working ok and I can open a new image.
If the problem was server based then Corel seem to have tweaked something?
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
Yes. Seems to now be working. Thanks Corel.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
hartpaul wrote:Yes. Seems to now be working. Thanks Corel.
Not sure they deserve thanks. They seem to have introduced the problem, however inadvertently, by their obsessive pushing of ads.
I still stand by my earlier suggestion of simply blocking all things Corel from the internet through your firewall, which I usually do with most programs and always with Corel because of their intrusive marketing strategy. You can always do manual update checks easily.
FWIW, my firewall is the free Zone Alarm, which makes it child's play to block anything from the internet. Whenever you install something Zone Alarm registers it, and those products can be seen in the Application Control settings, listed alphabetically. In my case, I just scroll down the listing to Corel (which shows the products as well as the Update Helper), then click on the question mark under the Outbound Trusted column for each and every Corel entry. This opens a menu with Allow, Deny, Ask. Click on Deny and it's done - the question mark turns into a red X.
There is no need to look for the path. If you want to know the path, the filename you're blocking and more details about the entry (e.g., Corel Paint Shop Pro X7 (32bit), you just click on it and the details (path, exact file name, version, etc.,) appears in the details pane below the listings.
The procedure listed earlier in this thread for Windows firewall sounds quite a lot more inconvenient, but that's just my opinion given I haven't had a need to try it. :-)
JoeB
Using PSP 2019 64bit
AndyRatchick
Corel programs: Paintshop Pro X9
Post by AndyRatchick »
Yep - confirming this is now fixed for me too - I can create new images properly without crashing and I can download the purchased items from the store again.
Zantara
processor: i5-2100 3 10 Ghz
ram: 12Gb DDR4
Video Card: Intel UHD graphics 620
Hard_Drive_Capacity: 256SSD 1TB
Corel programs: From PSPX2 to PSP2022
Post by Zantara »
Still crashing here (The Netherlands)
theavy
motherboard: Dell 0CNDTP A00
processor: Intel Core i7-9750H
Video Card: NVIDIA GeForce RTX 2060 6GB
sound_card: NVIDIA Virtual Audio Device Wave Extensible WDM
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Generic PnP Monitor (17.1"vis)
Corel programs: PSP X9 thru 2022 - VS 2020, 2021, 2023
Post by theavy »
Ah ha... mine is working now. No reply yet from Corel support.
Zantara
ram: 12Gb DDR4
Post by Zantara »
RWCH wrote:Hi all,
I might have a simpler solution/workaround. I just modified the configuration file "IPP.CFG" in folder C:\ProgramData\Corel\Corel PaintShop Pro X9
I changed the content to:
SERVER_URL=https://localhost
REST_SERVER_URL=http://localhost
REQUEST_SERVER_TIMEOUT=3000
CHANNEL=Corel
Note: If you cannot modify the file, copy it first to a temp folder, modify it, and copy it back.
This worked after a new installation on a machine which did not have any previous installations of PSP.
It worked with the (trial) version (19.2.0.7.x64), which I downloaded today at 3:30 PM (GMT+2). They might have patched the software already , but I doubt it.
Still have to test it at home (I am at work now).
Can somebody confirm this works?
Thanks.
RWCH
Hiya,
Had to quote the whole post, as it is pushed back a bit.
No trouble changing the file. Opens in Wordpad.
But same difference, I'm afraid with trying to open a new image.
So that doesn't seem to solve it either. For me, that is.
I do have the full version (not an activated trial version) with all 4 updates installed.
However, I have both X7 and 2018 installed, which will have the original IPP file. Wonder if you have to change all the files.
UPDATE: changed the IPP.cfg files for all installed versions. Same difference. Won't open a new image in X9.
No problem opening new image in X7 but didn't like to do it in 2018, after changing the files.
I should reboot or shut down after the change, but I'm ready to shut down for the day.
Will try X9 in the morning and let you know. But by then it might have been resolved anyway, as for some it's working again.
Still...can't hurt to change the files, regardless of this X9 glitch. Thanks for sharing.
JoeB
ram: 8 GB
Post by JoeB »
Zantara wrote:Still crashing here (The Netherlands)
If you have blocked PSP from accessing the internet you might have to restore it to allow it to get whatever fix Corel made on the server.
JoeB
Leslie
processor: intel core i7
ram: 32 gb
Video Card: intel iris
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Dell Inspiron 7700 27 All-in-One Desktop
Corel programs: 2019 Ultimate, 2022 Ultimate
Post by Leslie »
working now.
East Coast USA
Muriel
Post by Muriel »
I installed brand new Version X9 on my Windows 8.1 computer yesterday and immediately ran into the frustrating and annoying issue everyone else on the planet seems to be encountering.. Happily and thanks in no small part to the role played in this forum, this morning it works as nature and Corel intended. I am delighted, and a HUGE thank-you to the folks who made this happen. :D
tsoilihoi
motherboard: Dell proprietary
processor: Intel i5 4460 CPU 3.20GHz
Video Card: Intel HD Graphics 4600
sound_card: Intel display audio
Monitor/Display Make & Model: Dell 22 in touchscreen
Corel programs: paintshop pro, corel video, photoimpact
Post by tsoilihoi »
I suspect that Corel has suspended the pop up ads for the new version that showed when the program opens.
All seemed to conclude that Corel's server was causing the problem.
This morning a tech went on my machine, played with the Microsoft distribution modules, resetting them, reset defaults on the program
with no luck. He concluded that it wasn't my machine or a windows problem. Anyway the timing of August 5th and the cross platform problem
points to a server side problem.... FAKE NEWS! lol
Zantara
ram: 12Gb DDR4
Post by Zantara »
Ah...yes. Will try that later in the day. :wink:
