Just to clarify, probably a misunderstanding of the point I was trying to make. Based on your query, I was just saying that color/contrast enhancement were generally preferred to make an image look "sharper" over an actual sharpen tool because of the artifacts introduced by sharpen tools. In other words, contrast/color enhancements would be my preferred "sharpen" method, although not considered sharpening but properly done can give the perception of a sharper aspect to an image. I wouldn't want that to be taken as meaning that I would use it where it was inappropriate to the subject matter. As per your example, if that image needed sharpening I would not do color enhancement to give the effect of a sharper image, but I would try some Clarify to see how that worked. And I would, of course, use sharpening tools if necessary rather than trying to enhance colors because, of course, they would be muted in an overcast and/or misty/foggy environment.photodrawken wrote:(BTW, I'll always strongly disagree with your views about colour enhancement (and contrast enhancement, too). For me, it's absolutely critical to maintain the emotional feeling of the original subject. If the picture was taken on an overcast day, those quiet subtle colours must be preserved. Just my opinion, of course.
What do you like in PSP 2018?
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
Re: What do you like in PSP 2018?
JoeB
Using PSP 2019 64bit
JoeB
photodrawken
- ram: 16Gb
- Hard_Drive_Capacity: 324Gb
OK, understood!JoeB wrote:Based on your query, I was just saying that color/contrast enhancement were generally preferred to make an image look "sharper" over an actual sharpen tool because of the artifacts introduced by sharpen tools.
Ken
JudyM
- processor: 3.40 gigahertz Intel Core i5-4670
- ram: 2048 MB
- Hard_Drive_Capacity: 999.36 GB
- Monitor/Display Make & Model: HP L1706
- Corel programs: PSP 9,X, X4 - 2018
Firstly, I was able to load my workspace [with all my customisations] from X9 without any problems.
I love the clone tool. Being able to line up clones accurately is a big plus.
The ability to change the node size in vector drawings is a great help when editing.
I was having problems with text on a path in X9 - none in this version
I like the justification options for large blocks of text.
The tools all seem to be working faster.
I like those cross hairs now in the selection tool -although I can't say that I had problems lining up a selection before.
Many thanks for the many tips from contributors
Now a query- can I download a trial of 32 bit version as well as 64 bit? I was able to download the "PSP2018Installer_32bit.exe" file but I could go no further with installation. I'd like to try out my 32bit plugins.
JoeB
- ram: 8 GB
I'm not sure but I think if you downloaded the trial version then it's only 64bit. If you downloaded a purchase version then you should have received an installer that gave you the option to select whether you wanted to install both the 32bit and 64bit versions, which will also show that option as the recommended option, rather than just either the 32bit or 64 bit.JudyM wrote:Now a query- can I download a trial of 32 bit version as well as 64 bit? I was able to download the "PSP2018Installer_32bit.exe" file but I could go no further with installation. I'd like to try out my 32bit plugins.
JoeB
JoeB
JudyM
- ram: 2048 MB
Thanks Joe!
Judy
Judy
bowserb
- motherboard: Dell XPS
- processor: Intel quad core
- Video Card: ATI Radeon HD 3600
- sound_card: Integrated on mobo
- Hard_Drive_Capacity: 3TB
- Monitor/Display Make & Model: Dell 19" x 3
Can someone answer this? Is there a setting in 2018 to have the program DO NOTHING WITH COLOR MANAGEMENT? I use three monitors with profiles created by ColorMunki, and X9 automatically takes the Monitor 1 profile and applies it to all three, making photo editing impossible on my large center monitor. No matter whether the Enable Color Management box is checked or not, this happens when x9 starts, and I have to restart the computer to get the monitors right again. Photoshop CS6 (and prior) plus Photoshop CC and Adobe Lightroom do not mess with my monitor profiles. Why can't PSP leave them alone too?
So, rant is over, but I'm tired of sending Corel $80 or so every couple years just to find out they still don't understand that they need to leave my monitors alone! Thanks.
Bill
Bill
Kathy_9
- Hard_Drive_Capacity: 2TB
File -> Color Management -> Color Management -> Un-check "enable color management"bowserb wrote:Can someone answer this? Is there a setting in 2018 to have the program DO NOTHING WITH COLOR MANAGEMENT?
bowserb
File -> Color Management In-check "enable color management" is in X9 as well. It just doesn't work. Checked or not, the program applies the monitor one profile to all monitors. I was hoping to learn that maybe now it works.
Kathy, do you use multiple monitors and a profiling device like ColorMunki or Datacolor Spyder? If you use a single monitor, it's a moot point. Thanks for answering, though.
tomkinsrichard
- motherboard: hp pavillion
- processor: amd
- ram: 4 gb
- Video Card: radeon
- sound_card: hp pavillion
- Hard_Drive_Capacity: 500
- Monitor/Display Make & Model: lcd
A lot more people are responding to this post. In addition to my negative thoughts about PaintShop Pro 2018, it's turning out that it's not, Pro that is.
I am serious when I say, Corel has to step up to plate and truly address the specific feature requests that other have posted on regular basis, practically annually, and so far, all that Corel has delivered is fluff.
I write documents and in that past have used two monitors, wowee, it's great. I know that people doing photographic work and illustration want their products to be colour accurate, and that means specific calibrated profiles for each monitor in the workflow.
Hey Corel management, are you listening yet?
Cassel
- ram: 16Gb
- Corel programs: PSP 8 (JASC) to PSP 2023
Beware that this is NOT supposed to be the case. NEVER load a workspace from a previous version (or a later one for that matter) as each workspace includes information that is based on the specific tools and commands of that program version. Loading a workspace from a previous version means that you will NOT see anything related to new tools and you can get unwanted behavior of your loaded workspace. NEVER load another one, even if it LOOKS like it is working.JudyM wrote:Firstly, I was able to load my workspace [with all my customisations] from X9 without any problems.
Cassel
https://scrapbookcampus.com
Thank you all for your comments.
While I'm not a part of Corel's management team, all I can is, we at Corel are listening and monitoring feedback regularly.
As mentioned in my previous post or personal interactions with some of you, I cannot promise that we'll be able to address every issue or request cause we have a finite amount of resource. However, I can assure you that we've taken a (more) bottom-up approach in product development where we're delivering bug fixes and features based on user requests, usage analytics, and peer-to-peer task analyses. I would also add that we've worked directly with our users to design and review well over 95% of PSP2018's features and enhancements. Evidently, some features and enhancements were seemingly minute but it was crucial to allowing our users to work more accurately and efficiently. It was a part of PSP2018's philosophy of "You ask, We listened" and I hope to continue this mindset.
Anyhow, I've digressed. I just want to thank you for your constructive feedback. And yes, we're listening.
Best,
Neville Ko of behalf of the PSP Team
Best,
Hi Bowserb,bowserb wrote:Can someone answer this? Is there a setting in 2018 to have the program DO NOTHING WITH COLOR MANAGEMENT? I use three monitors with profiles created by ColorMunki, and X9 automatically takes the Monitor 1 profile and applies it to all three, making photo editing impossible on my large center monitor. No matter whether the Enable Color Management box is checked or not, this happens when x9 starts, and I have to restart the computer to get the monitors right again. Photoshop CS6 (and prior) plus Photoshop CC and Adobe Lightroom do not mess with my monitor profiles. Why can't PSP leave them alone too?
Bill
I tried contacting you via personal message (pm) on this forum but I didn't see a reply. Anyways, we cannot reproduce the issue as described in versions PSP 2018, X9.0 and X9.2. We used 1/ 2 / 3 monitors with Windows 7 /10, tried all combinations (had assigned 1 separated profile for each monitor), and the "disable color management" function seems to work properly without needing to reboot.
So we may need more info more you:
1. OS version (including build version if possible.)
2. OS bit version (32 bit/ 64 bit?)
3. Issue PSP version? (Please refer to attached screenshot as sample)
4. Issue PSP bit version (32 bit/ 64 bit)
5. System display adapter
6. System display adapter driver version (Windows bundled? display adapter official driver?)
7. What are the interfaces the 3 monitors connect to the system with? (Ex: Monitor1: Dell P2415Q(HDMI) / Monitor2: HP 27es(DVI) ...... )
8. If possible, can you provide a video of the issue?
You can reply by sending me a pm or directly in this thread.
Best,
nev
Trilliana
- Video Card: Intel UHD Graphics 730
- sound_card: ASUS Xonar DGX
- Monitor/Display Make & Model: EIZO EV2303W
- Corel programs: PSP 2022
Hello,
after all the problems listed here back to the original subject
After working several weeks I really do like two features. The one is the clone tool, being able to line up clones accurately saves me a lot of work. And then I
definitely like the possibility of saving the workflow as a log file, kind of substitute for a database à la PS & Lightroom. I guess I just have to change the extension to Pspscript to re-create a picture if it somehow gets lost or damaged (I always store all the TIFFs coming from Lightroom, resp. the Lightroom catalogue in a first workflow phase, then comes PSP to touch up, format and save as JPG). Or I can look up which plug-in I used to get that super-duper effect on a specific picture
. A suggestion, AKA wish for this feature: It would be nice to automatically have the name of the image file as a default for the log file name.
And yes, there is also the crop tool with the different grids, not only Rule of Thirds. And the possibility to de-clutter the Tools tool bar.
Have a nice day /evening /night
Trilliana
Trilliana
mushigirl78
- processor: Intel Celeron N3050
- ram: 4 GB
- Video Card: Intel HD Graphics
- Hard_Drive_Capacity: 500 GB HDD
- Monitor/Display Make & Model: HP 15-f233wm
- Corel programs: Corel Paint Shop Pro 2018
I upgraded from X5 so I see a ton of improvements!
I work with brushes a lot....so brushes larger than 999 px is a huge improvement. And the ability to import .abr brushes instead of having to convert them to a png and then creating the custom brush that way....LOVE!
The only thing I would love to see is a visual preview of the brushes in the brush variance palette with the settings you put in.
Thank you for all the improvements and I look forward to future versions!
- gtojon
- motherboard: ASRock X99X
- processor: i7 6850k
- ram: 64gb
- Video Card: Nvidia GTX 1080
- Hard_Drive_Capacity: 40tb
- Monitor/Display Make & Model: Samsung 55" 4k
- Corel programs: PSPX9, Video Pro X7
Image size has been expanded again. X9 was 20,000 & now 2018 is 40,000 pixels
Cheers, Jon
Cheers, Jon
