Annoying splash screen
delboy007
Post by delboy007 »
Please remove the annoying splash screen when I open videostudio. It locks my desktop so I can't do anything while it is opening.
Re: Annoying splash screen
We do not work for Corel and I guess they will not read this post, contact Corel Support to explain the problem, maybe they can reduce the size in future versions.
However Asik replied to a post explaining a workround -- here
http://forum.corel.com/EN/viewtopic.php ... 60#p344522
delboy007
Post by delboy007 »
same issue different version and the workaround still doesn't work. I would hope after an upgrade that Corel would have stopped this practice.
It doesn't matter how big the splash screen is, the developer has configured it to lock my computer until the splash screen has gone
rjkok67
motherboard: 2A9C 1.0
ram: 8120 Megab
Video Card: ATI Radeon HD 5450
sound_card: AMD High Definition Audio Device
Hard_Drive_Capacity: 2250GB
Monitor/Display Make & Model: Samsung SyncMaster [Monitor] (27.2"
Post by rjkok67 »
In VS10, I went into the program installation folder and deleted all files pertaining to (splash screen) in the name and that eleminated my splash screen.
In VS 2018 I took away the splash screen in a more professional way; one of the files in program folder is (splashscreen configuration settings) I changed 2 or 3 settings to -0-(zero)
and that eleminated my splash screen see attached photo. the reason I did this was because the splashscreens were causing delays in program startup at tim es.
Thanks for that rjkok67. It certainly works. And it is useful since asik's fix does not work for me with VS 2018 -- though it worked with previous versions. The problem with 2018 for me is that the 21.0 folder in C:\Users\[MyName]\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro (x64) does not contain an en-US folder as 20.0 and preceding versions do. Nor does it contain, as far as I can see, anything else relating to configuration of the splash screen.
delboy007
Post by delboy007 »
Brilliant !!! Works like a dream and loads much faster.
I contacted support and this is what they said:
"Sorry for the trouble you are facing. But splash screen is the default feature in the software where you can see the software new update. However for sure I will highlight your concern to our development team."
Maybe someone else can make some sense of that cause I can't.
I really like this software but Corel's hard sell I think is outrageous. I wasted an hour in the last version getting rid of ads that kept popping up in the system tray and elsewhere. You expect that kind of thing if it is free or trialware but not when you have paid for a licence. When I finally go rid of them I still had to look at a sales nag screen for the new version every time I opened the program.
canuck
operating_system: Windows 8.1
Post by canuck »
I don't know what ads popping up in the system tray you are talking about - I have never seen any
delboy007
Post by delboy007 »
Then you are very lucky. It was in version X10. I had to contact support who gave me the details below . Then I had to get back to them again because there was another popup somewhere else. It wasn't even just for videostudio updates. They were trying to sell me their other products. It was acting like malware in my system tray.
Open up a run prompt by holding down the windows key on your keyboard + the letter "r"
2. Type Taskschd.msc and press ok.
3. Once the Task Scheduler app appears highlight the Task Scheduler Library Folder towards the top left.
4. The box on the right will show you what programs have scheduled tasks.
5. Locate the CorelUpdateHelperTaskCore task and right click on it.
6. Choose disable.
7. Close the window.
faizoro
Hard_Drive_Capacity: 500GB
Corel programs: VideoStudio 10
Post by faizoro »
I find the easiest way to get rid of the splash screen is to rename the SplashScreen.ini file to SplashScreen.ini.bak (which makes it inaccessible to the software which wont be able to find the renamed file)
I chose to rename the file rather than delete it in case a future software update might cause the absent file to throw an error (though unlikely). That way I can replace it if I need to. Sort of my hippocratic way of touching computers.
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
But does this realy make VS faster to load?
Panasonic X900m, VXF1
delboy007
Post by delboy007 »
It is not the speed of loading that is the problem it is that the splashscreen can't be minimized or closed, with no splashscreen I can at least get on with something else while I wait for it to load.
RickMen
motherboard: Gigabyte B660M GAMING AC DDR4
processor: Intel i7-12700F
Video Card: NVIDIA GeForce GT 730
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500GB M2 PCIe NVMe SDD
Monitor/Display Make & Model: Philips 246V5 24inch wide LCD
Corel programs: VS2022 Ultimate, VS2018 Ultimate
Post by RickMen »
Thanks rjkok67, it worked for me.
Sony FDR-AX53, JVC Everio GZ-HD40
delboy007
Post by delboy007 »
Yes it does work but the question is should having paid for a product should we have to go mess around like this. We have to disable the splash screen, then disable the outrageous system tray adverts for new versions and even after all that every single time I open the program the default page is yet another advert pushing me to upgrade. I asked support how to get rid of that and got no reply. I don't know of any other software that behaves in this way.
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
delboy007 wrote:Yes it does work but the question is should having paid for a product should we have to go mess around like this. We have to disable the splash screen, then disable the outrageous system tray adverts for new versions and even after all that every single time I open the program the default page is yet another advert pushing me to upgrade. I asked support how to get rid of that and got no reply. I don't know of any other software that behaves in this way.
DelBoy, it's a 60$ software, they have to make a buck. you want less annoyances go for 300$ one...there will be other annoyances
delboy007
Post by delboy007 »
Price has nothing to do with it. I don't know of any other software including free and those costing less than $60 that behave like this. Most companies ask if I want to be advised of new releases regardless of the price of their product
And as planting popup adverts in my system tray without permission how can that be reasonable ? Imagine what the system tray would be like if all software did that ?
