Installshield says it cannot find my existing version of VS9 in order to install the patch. I put the patch in the same program fles directory for ulead and no go. Any suggestions? Thanks
Ed S.
Patch install can't find VS9
- michaeltee
- motherboard: HP 82F1
- processor: Intel Core I5 7400 3 GHz
- ram: 16 GB DC
- Video Card: Intel HD Graphics 630
- Hard_Drive_Capacity: 2TB Hybrid
- Monitor/Display Make & Model: Samsung S24D300
- Corel programs: Installed: PS Pro 2021, VS Ultimate 2020
Re: Patch install can't find VS9
Are you trying to patch a trial version of VS9? If so, you might need to install the paid version in order to run updates, patches, etc.edward19283 wrote:Installshield says it cannot find my existing version of VS9 in order to install the patch. I put the patch in the same program fles directory for ulead and no go. Any suggestions? Thanks
Ed S.
-Mike
edward19283
- michaeltee
- ram: 16 GB DC
I'm not sure because after using the trial I bought a boxed copy. I believe somewhere in their FAQ Ulead mentions that the trial should be uninstalled before installing the paid **and** that the paid should NOT be installed in the same directory you used for the trial.edward19283 wrote:I downloaded the trial and paid for it and activated it. Is there another version for paid registrants? THe Ulead install file which I used to install the program is named: uvs9_tbyb_e_ulus.exe.
I'm not sure if any of this will solve your problem but prior to installing the paid I had the same issue as you, unable to run patches and updates.
-Mike
tbyb
I guess this is a try before you buy version download of your VS9. This is only a trial version having tbyb in its file name. If you happen to lost your download link from them after your purchase, you may contact their technical support. I think you have to resend your confirmation email from your purchase.edward19283 wrote:THe Ulead install file which I used to install the program is named: uvs9_tbyb_e_ulus.exe.
†bryave
