Wacom Intuos Pro
Wacom Intuos Pro
Hi!
I am a newbie using Corel PSP X6 (64 bit) and I have a Wacom Intuos Pro (Small) v. 6.3.22-6 both running under Windows 7 Pro (64 bit).
The tablet is connected to the PC via USB and I can open the Wacom Desktop Center. That it is!
How can I test if the table is turned on? How can I test if the tablet works with Corel PSP X6?
Thank you!
Doctor T
Thank you!
Doctor T
Dr. Anthony Rodriguez
http://www.AcrylicMath.com
brucet
Re: Wacom Intuos Pro
PSP should pick it up automatically. Just as it does with a mouse. Simply open PSP and try using the pen.
If nothing works go to File/Preferences/Miscellaneous. Check 'Disable pressure support .........'
regards
regards
Dijenga
- motherboard: Micro Star International
- processor: Advanced Micro Devices
- ram: 8gb
- Video Card: ati 5750
- sound_card: Soundblaster X-Fi
- Hard_Drive_Capacity: 1tb+
- Monitor/Display Make & Model: 2 ea 23" HP Monitors
- Corel programs: PSP(U) X8,X9,2018 VS(U) X8 & X10
You may find some of the information in this thread helpful:
http://forum.corel.com/EN/viewtopic.php?f=56&t=60373
Still learning, but here are a few of my favorite shots: https://www.500px.com/ccjr221
Dear Brucet,brucet wrote:PSP should pick it up automatically. Just as it does with a mouse. Simply open PSP and try using the pen.
If nothing works go to File/Preferences/Miscellaneous. Check 'Disable pressure support .........'regards
Thank you for your reply.
I got the table working.
Doctor T
Dear Dijenga,Dijenga wrote:You may find some of the information in this thread helpful: http://forum.corel.com/EN/viewtopic.php?f=56&t=60373
Thank you for the link. Very helpful!
Doctor T
Intuos Tablet Settings
Hi!
I tested the tablet and it works with PSP. But, I am confused about the tablet settings.
In the Windows Control Panel -under Hardware and Sound- there are three tablet-related options: (a) Pen and Touch, (b) Tablet PC Settings, and (c) Wacom Tablet Properties.
Additionally, there is (d) the Wacom Desktop Center on the PC and there are (e) controls on the Intuos tablet itself.
Finally, there are (f) controls within PSP itself.
Which of the six do I use?
Thank you!
Doctor T
Thank you!
Doctor T
brucet
Re: Intuos Tablet Settings
I'm not in front of my editing computer at the moment. But to the best of my memory I did all my Wacom settings via the Wacom Desktop Center. By setting up via the Wacom Desktop Center your settings should be ok for all programs.
bruce
bruce
Dijenga
- ram: 8gb
"Pen and Touch" as well as "Tablet PC Settings" are not for your Wacom tablet. Those are (if memory serves) for touch screens, not graphic tablets. Just use the "Wacom Tablet Properties" to make any adjustments.DoctorT wrote:Hi!
Thank you!
Doctor T
Don't know about your tablet, but play around with the sensitivity ... for mine, the more sensitive I make the settings, the harder it is to use properly. Less sensitive gives you better control of "Pressure" and thus makes it more like an actual brush.
Use the brush variance palette in PSP to determine how your software interprets pressure on strokes.
Dear Brucet,brucet wrote: ... Wacom Desktop Center ...
Thank you for your reply. Makes sense.
Doctor T
Dear Dijenga,Dijenga wrote: ... Wacom Tablet Properties ...
Thank you for your reply. Makes sense too.
Doctor T
Hi!
Brucet uses the Wacom Desktop Center and Dijenga uses the Control Panel's Wacom Tablet Properties. Again, thank you for your replies.
And, It appears that the controls on the tablet itself are shortcuts to the Wacom Desktop Center.
Finally, nobody suggested to use the PSP controls.
I got work to do.
Doctor T
I got work to do.
Doctor T
brucet
When you first start using your Wacom in PSP I would suggest selecting a brush of some sort. Then go to Palettes/Brush Variance. Go down to Size and select Normal. Why? Because if you select Pressure, which was my default, then you may not see any visible results. This may be the case for all your brushes until to get the hang of things.Keep testing until you have it all working. FWIW I set all my brushes to Normal. But that's only because it suits my work style.
bruce
bruce
Dear Bruce,brucet wrote: ... When you first start using your Wacom in PSP ...
Again thank you for your advice.
Docror T
