New to ASP3 and photo editing in general. I just installed the program and I continuously get the "Select a destination" pop-up window. I select a folder and after a few seconds the pop up appears again. If I hit cancel, a window stating that the batch was not processed appears. When I do select a folder, the photo goes to gallery batch. Any help on how to stop the continuous asking to send a photo to gallery batch?
Thanks,
Tinglypeanut
Problem with continuous batching?
Tinglypeanut
- Corel programs: AfterShot Pro 3
Dutchmm
- System_Drive: N/A
- motherboard: Asus 97
- processor: Intel i7 4785T
- Video Card: Onboard Intel
- sound_card: Intel AC97
- Hard_Drive_Capacity: 2.5TB
- Monitor/Display Make & Model: Philips 28"
- Corel programs: ASP 3 Pro (and 2 and 1 before)
Re: Problem with continuous batching?
You can set the destination folder in the Batch Settings, "Output Name and Location", if it will always be the same. Otherwise, you have to select a folder every time you use a batch.
Alternatively, what I do is use colour coding to sort a day's shots by intended destination folder, then use filtering by colour to select them when I have finished the triage, Ctrl-A to select all photos with a specific destination colour, then send to batch, which means I only specify the destination folder once per destination.
