How to make super slow motion video in VS X9?
jungleexplorer
motherboard: Gigabyte GA-B460M DS3H AC V2-Y1
processor: Intel Core i5-10400F
ram: 16GB DDR4
Video Card: Nvidia GTX 1660S Super
Hard_Drive_Capacity: m2 SSD 1TB
Monitor/Display Make & Model: ASUS VS248H-P 24" Full HD
Corel programs: VS 2022: PSP 2023
Post by jungleexplorer »
I want to make some super slow motion video. In VS X9 I can adjust the speed of the video down in Attributes tab, but not far enough. Is there another way to slow the speed of the video down further?
I'm sorry for my sins Jesus, please forgive me. https://sorryformysins.com
Terfyn
motherboard: ASUSTeK P8H61-MX
processor: Intel Corei5-2320
ram: 8Gb
Video Card: NVIDIA GeForce 210
sound_card: NVIDIA High Def Audio
Hard_Drive_Capacity: 1000 Gb
Monitor/Display Make & Model: Acer & LG
Corel programs: VS X10 and PSP X8
Re: How to make super slow motion video in VS X9?
Post by Terfyn »
You would need to start with a camera that does Slow-Motion recording, for example, the Panasonic 750, this does half speed and quarter speed as an MP4 file which can then be slowed down in VS. You need to have the number of frames that will allow even more Slo-Mo otherwise you are over duplicating the number of frames in your original video.
This is not a fault in VideoStudio, you need to start with the right information on the video.
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
You can try converting your video to JPG images, I use Free Video to JPG Converter
https://www.dvdvideosoft.com/products/d ... verter.htm
You select a range of your video to convert, lets say 1 min, this will create 1800 images (30 fps), import into VS and change the duration of the images.Each image has a duration of 1/30 of a second, so if you select 1 second duration, you have slowed down 30 times, play around with it to obtain the speed you require
