Moving object blurs badly after rotating image.
JimTrail
motherboard: Lenovo 7033AE8
processor: Intel Core i7-2600 at CPU 3_40 GHz
ram: 8 GB
Video Card: Intel HD Graphics
sound_card: Microsoft High Definition Audio Device
Hard_Drive_Capacity: 219 + 1TB
Monitor/Display Make & Model: Samsung S22B310B
Corel programs: CorelDraw 2017, VideoStudio 10X (Trial)
Post by JimTrail »
Hello Forum;
Version:
VideoStudio X10, trial version
Video Properties
File format: MPEG-4 File
File size: 11,634 KB (11.3 MB)
Duration: 20.329 seconds
Video type: H.264 High Profile Video
Total frames: 595 frame(s)
Attributes: 24 bits, 1920 x 1080, 16:9
Frame rate: 29.268 frames/sec
Data rate: 4541 Kbps
Audio Type: MPEG AAC Audio
Total samples: 899,072 Samples
Attributes 44100 Hz, 16 Bit, Mono
Bit rate: 144Kbps
Before rotating (left) - after rotating (right)
MrJohnny
motherboard: ASUSTeK COMPUTER INC. RAMPAGE V EXTREME
processor: 3.00 gigahertz Intel Core i7-5960X
ram: 32GB
Video Card: NVIDIA GeForce GTX 960
sound_card: onboard
Hard_Drive_Capacity: 8TB
Monitor/Display Make & Model: ASUS VH226
Corel programs: VS X5 Ult, VS X6 Ult, VS X9Ult,VS X10Ult
Re: Moving object blurs badly after rotating image.
Post by MrJohnny »
Was the Rotation through 180 degrees accomplished using the Rotate Filter? If not, how?
Why is the original footage upside down? :roll:
Have you got another method of rotating the original footage? Eg FFMPEG
John
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Hard_Drive_Capacity: 1TB
Post by tletter »
JimTrail wrote:Moving object blurs badly after rotating image
Never experienced this using the 'Rotate Left' or 'Rotate Right' buttons on the Video tab. Is this how you rotated the video?
JimTrail
ram: 8 GB
Post by JimTrail »
JimTrail wrote:Hello Forum;
Version:
Video Properties
Bit rate: 144Kbps
The post above excluded the two images below. It also excluded my description of the problem.
It's not the moderators fault.
It's this forum software. It does not work very good. I am familiar with phpBB. It's open source. I've uploaded phpBB to a server hosting I have had in the past. The programmers don't get paid. Corel needs to get a better software program, like vBulletin maybe, for the forum.
Description of the problem
I have got a LG Nexus 5x Android phone. I took the video with the phone. I have got an app for the video camera. It's called "Cinema FV-5." For some reason it records the video upside-down. Other than that it works great.
When I rotate the video right-side-up the person in the video blurs when he moves. I am trying to figure out how to keep it from blurring. The video doesn't blur when I leave it upside down.
I have been using CorelDraw since the late 1990's decade. I have a yearly subscription to CorelDraw.
Corel designed the CorelDraw program from scratch. It improves and gets more sophisticated with each release. I prefer to use a Corel product since I am already familiar with the company.
I would appreciate any suggestions.
Thanks.
These are the two images I uploaded on the first post per the instructions at this link:
http://forum.corel.com/EN/viewtopic.php?f=1&t=8959
Properties
Properties
Project properties
Project properties
JimTrail
ram: 8 GB
Post by JimTrail »
Hello John;
Thanks for responding.
MrJohnny wrote: Was the Rotation through 180 degrees accomplished using the Rotate Filter? If not, how?
I rotated it using options -> rotate left/right arrows. I couldn't figure out how to use the Rotate Filter.
MrJohnny wrote: Why is the original footage upside down? :roll:
It's upside down because of an app I have got for my Android. It's called Cinema FV-5. I think the developer meant for it to be that way. I don't know the reason.
There are a limited number of apps for video cameras for Androids like mine. Other than the video being upside down everything else is nice. It's easy to use. I like it a lot.
MrJohnny wrote: Have you got another method of rotating the original footage? Eg FFMPEG
WOW! I'll check out that FFMPEG.
Thanks again.
JimTrail
ram: 8 GB
Post by JimTrail »
Hello tletter;
Yes, I used the Rotate Left and Rotate Right buttons. It could be the app I am using is not doing something right.
Thanks again.
MrJohnny
ram: 32GB
sound_card: onboard
Post by MrJohnny »
Hi Jim
The programme supplied with the phone, can it rotate?
The frame rate looks odd - but the duration/fps do line up to suggest a fixed frame rate, can you confirm - say use MediaInfo to interrogate the file?
Try running the original MP4 file through Handbrake - then import that to VS. Does it still blur when rotated?
The Rotate Filter uses keyframes, but if you rotate at the first keyframe (beginning of the clip) it should maintain the rotation throughout. Never had blurring with it.
John
I suspect it really has something to do with a variable frame rate, and it seems to me that your Nexus really is using a variable frame rate. The Properties box shows a frame rate of 29.268 fps while the Project Properties -- I suspect derived from the frame rate of the first part of the first clip put in the timeline -- shows a slightly different frame rate of 29.29 fps. It may not be much, but that really does suggest a variable frame rate throughout the whole video. The "correct" fixed frame rate should of course be 29.97 fps. We already know that Video Studio does some strange things when confronted with variable frame rate video, and it could be that in this case the vraiable frame rate produces smearing when rotate is used. So I would endorse MrJohnny's suggestion of running the video through a video converter to produce a fixed rate video, and then try rotating that.
Post by BrianCee »
Have you tried using the 'Flip' filter in the 'FX' library - by default it flips horizontally - but you can customise it to flip vertically - may just be different doing it in one movement
