Just bought an analog capture device, but VS8 won't let me..
julia_lunquist_84
Post by julia_lunquist_84 »
VS8 won't let me select 720x480 resolution. Maybe I am doing something wrong. On the capture screen, I clicked on "options" then selected the capture tab. For "frame size", I clicked on the dropdown menu and it only lists resolutions from 160x120 to a max of 352x288. The capture device I bought (CameraMate Real Time Video by Zio), does 720x480. Why won't ULead list 720x480 as an option?
jchunter_2
Post by jchunter_2 »
The usual reason this happens is that one of your connectors is a USB1.0 connection, which can't handle video bandwidth. Your capture device has a USB2.0 connector - so - what about your computer?
julia_lunquist_84
jchunter_2 wrote:The usual reason this happens is that one of your connectors is a USB1.0 connection, which can't handle video bandwidth. Your capture device has a USB2.0 connector - so - what about your computer?
But the included software with CameraMate allows me to do 720x480 and it was in the same USB port.
Merlin
Post by Merlin »
Perhaps, your project setting in Video Studio is set for VCD not DVD?
julia_lunquist_84
Merlin wrote:Perhaps, your project setting in Video Studio is set for VCD not DVD?
Nope, it's definitely set to DVD.
THoff
Post by THoff »
See if changing the Capture Plugin in the Tools menu makes a difference.
julia_lunquist_84
THoff wrote:See if changing the Capture Plugin in the Tools menu makes a difference.
Won't work. This is strange. Anyone have any ideas?
jchunter_2
Julia,
Capture to mpeg2 with the software that came with the device. Then edit with Video Studio. This is usually what I do because Uleads support of capture boxes is spotty.
THoff
Post by THoff »
To be precise, Ulead doesn't support proprietary capture devices, it uses the standard video capture interfaces that exist, i.e. VFW, DirectShow, MiniDV, MicroDV, and even DVD/DVD-VR. If a hardware manufacturer elects to provide their own interface instead of complying with one of these, you can't exactly blame Ulead.
ggrussell
Propietary interfaces
Post by ggrussell »
And this isn't unique to Ulead either. I see lots of people having trouble with ATI capture cards on several other forums. Cross your fingers and hope that the software that comes with the card also uses standard MPEG2 files. :wink:
Phenom X4 965 3.4Ghz, 8gig DDR3, 120GB SSD, 1TB HD, 500GB, Bluray & DVD Burners, ATI HD5550, Epson scanner, Canon 9000Pro, Sharp AL1551CS laser printer, Sony TRV740 8mm digital, Canon HV20 and Sony SLTA65VK, Win7 HP 64bit
Gary Russell
TNUSA
Bigcot
Post by Bigcot »
I also have Cameramate Real Time Video and it too also gives me only a max resolution of 352x288. I'm not quite sure if there is a solution to this problem. I am thinking that maybe there is a clash between the program and the capture device. Maybe Ulead doesn't offer full support for this video device. When I use the software that came with the program it enables me to record at 720x480. I have all the drivers installed and my system specs are:
AMD Athlon 64 3500+
1 Gig of DDR 400 Ram
160 Gig hard drive
Asus A8V motherboard
GeForce 6600 256 DDR ram
If anyone has found a solution to this problem please notify me I would really appreciate it. I am going to send an email to Ulead support or somthing.
