I am having a problem creating text on a path around an object.
After making sure I have created a path, I find that when applying text, the symbol for text on a path appears but the text still wraps inside the object.
Is there a trick to making it work?
I have never had problems creating text this way before.
Judy
X9 Problem text on a path
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: X9 Problem text on a path
Select the path
Go to the menu: Objects - > Edit -> Reverse Path
Is the text now along the outside?
JudyM
- processor: 3.40 gigahertz Intel Core i5-4670
- ram: 2048 MB
- Hard_Drive_Capacity: 999.36 GB
- Monitor/Display Make & Model: HP L1706
- Corel programs: PSP 9,X, X4 - 2018
Levi
I tried your suggestion and ended up with text following the path reversed but again inside the object as if it was offset.
I then reversed the path again and this time the text ended up a big tangled mess.
I created a new path and it worked perfectly!
Search me!!!!!!!!!!!!!
I must have a bug in there somewhere.
Thanks for your help as always.
Judy
Judy
