Manage Tab -> Edit Tab glitch
karebai
processor: AMD DualCore A9-9410
Video Card: AMD R5
Hard_Drive_Capacity: 1TB
Corel programs: PSP7;PSPX;PSPX9;PSP2019 Ultimate
Post by karebai »
PSP X9 (19.2.0.7), Win10 CU. This problem was happening before the CU, before the latest PSP update, if fact I was hoping the problem would be fixed in the PSP update.
I open in the Edit mode, go to Manage, find the image I want. When I go back to Edit mode - this is what I get. I "lose" the standard toolbar, plus the rest of the options after File
I then have to reload my saved workspace to get everything back the way it should be.
Have I missed a setting somewhere, or what is upsetting things ?
TIA
MarkZ
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Re: Manage Tab -> Edit Tab glitch
Post by MarkZ »
Try resetting PSP. Save your workspace, close PSP then after a while restart it while holding the shift key. You will be asked if you wish to reset the program to initial settings.
I suggest you see if the Manage/Edit transition works correctly before reloading your workspace.
Mark
karebai
Video Card: AMD R5
Post by karebai »
Thanks MarkZ. Apologies for not responding sooner, but I haven't been able to devote a block of time to sort this out until now.
I had previously tried resetting, and it didn't seem to work. So I tried again. Everything seemed OK, but no, it happened again.
So, I've reset, again. This time I've tried older saved workspaces, I've slowly added all my preferences (on previous attempts I did all my file locations straight after checking the manage/edit switch), and it seems to be working as it should.
Now to see how long it lasts this time ...
