Any insight on how to achieve this would be greatly appreciated! Thanks in advance.
I'm not the OP but when I open Nik ColorEfex Pro from the Nik Collection plugins in PSPX7 32bit or 64bit with a jpg open it opens the plugin interface then X7 crashes and closes.brucet wrote:First quick thought is to try a plugin such as Topaz Impressions. Maybe Nik ColorEfex pro will do the job. Or for smaller jpegs FotoSketcher. There are 'cartoon' presets that will give you a starting point.
Topaz Clean should give you the effect you are looking for.Grundberg wrote:I would like to learn how to convert a photo to a vector/line art/drawing style representation. Here's an example of what I'd like to accomplish:
it's amazing how poorly software that should be mutually compatible proves to be incompatible. PITA!brucet wrote:Sorry folks. I only use x8. So when I tried x7 guess what? It crashed.
Hmmmmmmmm.
Just because I like to try stuff out, I have tried the Trial version of cartoonize and using Kathy's suggestion about using Topaz Clean to achieve the effect that the OP asked about. IMHO, the Topaz Clean method is much preferable. The main reason is that there are many more manual adjustments in Topaz that a user can use to modify the various presets to fine tune ('toon?) the effect. As well, simply mousing over the various presets instantly shows what it will look like on the image. With Cartoonize, the presets are pretty small and it's quite difficult to determine exactly what they will look like when applied. And it takes many seconds, after you click on a preset, for the program to process the change. Also, there's more you can do with Topaz Clean than just cartoonize.Jean-Luc wrote:Try http://www.cartoonize.net ...
Actually, I think that's a good idea, and one I never considered just using PSP tools. If you think about it, the pro tools like Topaz, etc., are doing the same thing in the end. They just make it easier because of the extra manual sliders you have for fine tuning within the same interface, whereas in PSP you still would have to go to other tools for fine tuning the result of your color reduction, so definitely the PSP alternatives would be more hit-and-miss with lots of undoes, retrys, and time spent to get where you want to get. But still, I think you pointed out a good start point for those wanting to just stay within PSP, and for any stalwart who feels the urge to create a script for just doing this type of cartooning effect.StoryMaker wrote:I doubt the effect would be as good as a professional tool, but you could try reduce the color depth of the image to a lower number of colors. It's certainly simple and probably doesn't look super great on a photo, but it's something to try if you're looking for a free option. I'm not sure if this can be done in a newer version of PSP; I've done it either in an old version (Jasc version 9) or with the free tool IrfanView. Afterwards, you'd probably want to convert it back to the normal color depth (16 million or whatever) so you can work with it without messing up any colors you add to it.
