Why only 99 clips per DVD?
MIKE@HOME
Is there some way of gettting more than 99 clips on a DVD, the clips are short so it is conceivable that 200 could fit onto 1 DVD.
htchien
In DVD spec, a DVD only can have 99 titles.
But if you have Ulead DVD MovieFactory 3 or later, you can use the Join Video feature in the Add/Edit Media page to join video clips. For example, if you have 2 video clips in the Add/Edit Media page and hold Shift or Ctrl key to click on both of them, then click on the Join Video button, they will be merged into 1 video clip, and the joined video clip will become a DVD title with 2 DVD chapters.
You can merge 99x99 = 9801 video clips into 99 joined video clips and burn these joined video clips as DVD titles in DVD MovieFactory.
Hope this helps.
H.T.
Hope this helps.
H.T.
IronMike778
Would you guys mind elaborating a little bit? I was under the impression there was a maximum of 99 clips in a project. How would you define 'clips' in the sense we are talking? I thought the 99 clip limitation meant I couldn't make one project in ULEAD 8 containing a combination of more than 99 video clips, titles, overlays, and jpgs in this one project.
I am wrong about this? Sounds like I am.
