"Open With.." Crash On Startup 'Workaround'
TroyTheTech
motherboard: Gigabyte Z370P-D3
processor: Intel i5-9400F
Video Card: AMD RX 5600 XT
sound_card: Realtek 8-Channel Onboard
Corel programs: PaintShopPro, VideoStudioPro
Post by TroyTheTech »
Just wanted to share something I ran into with VSx10 (it may also affect other versions of VideoStudio as well) - and also the very easy 'workaround' I figured out for it...
I actually write for a Blog and did a post about it there, but I will share the entire thing here, so noone has to go there to read it
(Now, this may seem like very novice information to you experienced users here, but I wanted to share it in case others have run into this issue - which has VS crashing just after the startup screen is shown)
For me, VideoStudio was crashing when it was starting up and I couldn't see why at first - I had changed nothing on my system and I was using it just the other day.
I tried different clips, I tried the clips in other video editing applications and the clips were fine, but VS wouldn't open, it would show the splash screen and then close, showing the error:
“Corel VideoStudio Has Stopped Working”
Corel VideoStudio Has Stopped Working - Copy.png (49.22 KiB) Viewed 3147 times
I tried reopening it a few times and realized I was using the Windows right-click option "Open With..", which allows users to 'send' a file to a program, essentially making the program open and start using that file right away - however this "Open With" option was working with other programs I have installed...
I looked at VS then, and saw that it was opening fine 'on it's own' (not using "Open With..") so I closed it and reopened it a few times, trying to figure out what it was. It dawned on me that I was opening VideoStudio to the "Welcome" area.
As users of recent versions know, this ‘Startup Page’ offers a lot of helpful information upon opening VS. There are Tutorial videos on some of the Features and even Basic Tutorials and Help File links. But wait - no editing interface! No Timeline, no Media Library to add clips - that's it! That's the problem!
I went into the Settings to see if there was a Preferences option where I could set the Section to open VideoStudio to be - not the "Welcome" section but the "Edit" section - the tab/area where all of the editing/mixing and importing takes place.
There it was: Default Startup Page - and it was set to "Welcome Book"...
A simple pull-down menu change to "Edit" and that was it! Now, VideoStudio is opening to the "Edit" section/area every time. So, I tested it out: right-clicking on my video clip and mousing-over "Open With.." and then clicking on "Corel VideoStudio" - it worked! VS opened up and in a few seconds more, my little video clip was right there on the Timeline, waiting patiently to be edited :!:
(Again, this might seem like a very 'newbie' issue for many of you, but when looking up 'videostudio crashing on startup' and similar terms, I found many, many people asking about the same sequence of events (splash screen shown, then the 'crash' and error message) both here and in other places - and I thought perhaps this might help those 'many' people experiencing this - just in case it is in fact this very same issue/problem and possibly the same solution...)
Davidk
ram: 16Gb
Hard_Drive_Capacity: 6Tb
Re: "Open With.." Crash On Startup 'Workaround'
Post by Davidk »
This welcome page/mode is new to X10 - prior versions did not have it, and normally opened to Edit mode. For x10 the welcome page was introduced, and if you look not too closely, it looks a lot like a Corel store.
So, most upgrading users will probably not have noticed that "set open to page" item you've identified, and be just living with opening to Welcome and then changing to Edit. So nice to find that is configurable, and I've done just that. Many thanks.
TroyTheTech
Davidk wrote:This welcome page/mode is new to X10 - prior versions did not have it, and normally opened to Edit mode. For x10 the welcome page was introduced, and if you look not too closely, it looks a lot like a Corel store.
You're most welcome! I couldn't remember if the earlier versions had a Welcome Page, thanks for filling that in - and yes it's nice to have it configurable (way to go, Corel devs!).
I'm glad that the information was found useful. Perhaps those coming from earlier versions can change this right off the bat (if they plan on using "Open With"), to avoid future troubles with it.
Hi Troy
Yes I can confirm that X10 does crash when opening the program using “Open With” and having the Welcome screen as default.
Although Open With is a legitimate windows process we normally would use that for project files VSP’s and not video files, MP4, MTS etc.
Choosing a VSP does not crash the program.
Unfortunately Open With for a VSP could open an earlier version of Video Studio, as the files associations have been known to be shall we say confused
I would advise opening the program from our desktop icons then add video files.
