VideoStudio Ultimate x7 won't open
Thordell
motherboard: Azus P8 H77-M M-ATX DDR3
processor: Intel CR Core TM i5 3470 CPU 320 GH
ram: 16gb
Video Card: Firewire
Hard_Drive_Capacity: 3TB
Corel programs: Corel VideoStudio X7 Ultimate
Post by Thordell »
Just wondered if anyone could help please. The other day after opening VS I clicked on FX and nothing Happened, it wouldn't open, no right clicking would work, so closed down and restarted the computer, started again, and still did it so restarted again, still the same so in the end I reloaded the programme from the disc, it reloaded the programme ok but now you can't open the programme, took it off and reloaded again but still won't open.
At the moment I've removed the programme from the computer, has anyone had this happen before.
Thanks, Alan
Re: VideoStudio Ultimate x7 won't open
Post by BrianCee »
Everyone running X7 had it about a year ago - have you used Videostudio in the last year ? - if not then you need to install the Hotfix which you will find here
http://www.videostudiopro.com/en/suppor ... sion-tab=3
Thordell
ram: 16gb
Post by Thordell »
Thank you Brian I'll try that
Thordell
ram: 16gb
Post by Thordell »
Just tried your link Brian and there is no download shown for the hotfix that i can see unless I'm being stupid
Found it, ....I'm stupid
Thordell
ram: 16gb
Post by Thordell »
"All's well that end's well" as Shakespeare said, a big thank you Brian found the file and loaded it and all working, thank you once again Brian
Post by BrianCee »
Thats very strange - when I click that link I see the following
click image to see it bigger
EDIT
ah I see you found it while I was off checking - I'll leave it there though in case any one else has problems
Thordell
ram: 16gb
Post by Thordell »
Just me having a silly morning
