resizing icons/toggles in palettes
Hello - I am new and I have a question regarding changing the size of the toggle/boxes in the palette and toolbars... I made them too small and cannot locate where to enlarge them.
They are located in the palette where you would check/uncheck the layers. Also the toolbar "icons". Any help will be greatly appreciated!
- hartpaul
- ram: 8 Gb
Re: resizing icons/toggles in palettes
View > Customize > Options Tab, - untick show small icons.
Right click in empty work space and select General Program Preferences and go to Palettes.
show small icons is already unchecked ty for your reply but didn't help me
Its the boxes in the layer palettes where you can close the "eye" the box that you check is super tiny
- hartpaul
- ram: 8 Gb
What version of Paintshop pro are you using?
Were the visibility icons larger originally?
If so you might save your workspace if you have customized it --File > Workspace > Save
Then reset PSP to its defaults by closing the program, then holding down the Shift key as you start it up again.
If this does not correct then it may be related to your monitor settings, / resolution.
