Hi So, I was making a video the other day, and when I got home and put the clips in the editor I noticed some smudge on the Lense of the Camera which slightly effected the picture of my footage and I want to clear this up.
Is there a way to do this in Corel?
Rob
How to fix Lense Smudge in Corel X10?
RobCharles1981
- motherboard: MSI MAG B650 TOMAHAWK
- processor: AMD Ryzen 7 7800X3D
- ram: 32gig DDR5
- Video Card: XFX 7800XT
- sound_card: Sound Blaster Z
- Corel programs: Studio Ultimtate 2023
Terfyn
- motherboard: ASUSTeK P8H61-MX
- processor: Intel Corei5-2320
- ram: 8Gb
- sound_card: NVIDIA High Def Audio
- Monitor/Display Make & Model: Acer & LG
- Corel programs: VS X10 and PSP X8
Re: How to fix Lense Smudge in Corel X10?
I guess it would depend on where the smudge is on the picture. I don't think you can get rid of something that has been recorded as part of the picture but if the smudge is close to an edge, you could try Auto Pan from the FX and try and move the picture to hide the smudge. Auto Pan will enlarge and shift the centre to hide the original edge. I don't think there is anything that will "rub" the lens clean.
Another option may be to put a mask around the picture. If you pull the clip down onto an overlay track and select mask from the Options, you may be able to hide the smudge if it is near the edge.
RobCharles1981
- ram: 32gig DDR5
Hi there,Terfyn wrote:I guess it would depend on where the smudge is on the picture. I don't think you can get rid of something that has been recorded as part of the picture but if the smudge is close to an edge, you could try Auto Pan from the FX and try and move the picture to hide the smudge. Auto Pan will enlarge and shift the centre to hide the original edge. I don't think there is anything that will "rub" the lens clean.
Thanks for the input.
What setting do I need to use in Options to tidy this up?
- TroyTheTech
- motherboard: Gigabyte Z370P-D3
- processor: Intel i5-9400F
- Video Card: AMD RX 5600 XT
- sound_card: Realtek 8-Channel Onboard
- Hard_Drive_Capacity: 512GB+4TB
- Corel programs: PaintShopPro, VideoStudioPro
If I may pop in with an idea - now I am picturing either translucent/transparent smudging, or a 'small' smudge - depending on the type of footage you are shooting for, you can try adding a Film Grain effect to the video. This effect is useful for hiding compression artifacts and small particles like dust, etc - I am thinking it can also be used to 'hide' smudging (depending on what type of smudge it is). Just an idea
Terfyn
- ram: 8Gb
Auto Pan is in the FX window and can be adjusted using the "cross hair" on the Customise Filter page. For the mask effect, the clip needs to be dragged into an overlay track and fitted to screen. Open Options, click on Mask and Chromakey then on Apply Overlay options. Open the drop down menu (it says Chromakey with a down arrow next to it) and select Mask Frame, choose a suitable mask from the panel that opens.RobCharles1981 wrote:Hi there,Terfyn wrote:I guess it would depend on where the smudge is on the picture. I don't think you can get rid of something that has been recorded as part of the picture but if the smudge is close to an edge, you could try Auto Pan from the FX and try and move the picture to hide the smudge. Auto Pan will enlarge and shift the centre to hide the original edge. I don't think there is anything that will "rub" the lens clean.
I hope you are able to tidy this bit of video somehow but remember "A clean lens is a happy lens"
RobCharles1981
- ram: 32gig DDR5
Would any of the "New Blue Video Effects" Help this in the FX Tab But which one?
Terfyn
- ram: 8Gb
In New Blue Video Essentials there is a filter called Touch Up. I tried it with a shot that included a wire mesh fence. It reduced but did not eliminate the wire of the fence. I, as yet, cannot see how you can remove a smudge completely as it is in the original video, if it was a photo (i.e. one frame) then you could copy some background over the smudge and eliminate it that way. Sorry to be of little help.
How is your bit of Wales. Are there any video clubs in your area?. Some photo clubs up here but no video that I can find.
- TroyTheTech
If I may be so bold as to ask: if it does not overstep any confidentiality/privacy boundaries, could you share a few seconds of the clip, so that those who wish to, can play with effects and filters that may help with it?
