PSP X9 Autosave File is not valid - resolved
ADonahoo
motherboard: Dell Inc. 0KWVT8 A03
processor: 3.60 gigahertz Intel Core i7-4790
ram: 24GB
Video Card: AMD Radeon R9 270
sound_card: Creative SB X-Fi Titanium
Hard_Drive_Capacity: 13256GB
Monitor/Display Make & Model: Dell SX2210 and Dell ST2210
Corel programs: PSP X7, X8, X9, 2018, 2019
Post by ADonahoo »
I get this message when I open the program. I have disabled Autosave, rebooted, re-enabled it. Reset X9 with the shift key. My recent files list is empty, although the last image I was working on had 28 layers, each one involve a separate image added. I really don't want to uninstall and reinstall X9. Does anyone have any suggestions?
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Re: PSP X9 Autosave File is not valid
Post by hartpaul »
Try turning on the autosave , working on a new image so that autosave is invoked and hope that a correct autosave will overwrite the damaged one. close program. Reopen and see if the message disappears and then turn off autosave.
ADonahoo
ram: 24GB
Post by ADonahoo »
I did that already, worked on the 28 layer image after resetting the Autosave. That was yesterday. Today I got the message again, and all the images I opened from the Manage tab, are not showing in my recent file list. I will try turning off autosave and working on a new image without it and then close and reopen the program.
Edit to add: I'm getting that message when I open X9 even with Autosave turned off. Where is this file saved?
hartpaul
ram: 8 Gb
Post by hartpaul »
Did a google search for location of paintshop pro autosave files and got a number fof hits. This looks closest to what you have.
http://www.tek-tips.com/viewthread.cfm?qid=1385476
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Post by Forriner »
You'll find where PSP saves those files under menu File\preferences\File locations... Undo/Temporary files.
For X7 under Windows 10, default:
drive:\Users\Your Name\Appdata\Local\Temp\Corel PaintShop Pro X7 Temp Files
In that folder PSP creates a subfolder like PSP12345_YourName, another PSPF123, and temporary save files go there.
Auto-save files are not normal image files as far as I can tell from a short test (I don't use the auto-save or -preserve facilities myself). With two open images and one edit each I got 4 xxxx.TMP files.
These files were erased by PSP when the workspace images were closed normally.
Good luck.
ADonahoo
ram: 24GB
Post by ADonahoo »
I found the folder, right where it was supposed to be. X9 had 562 zero byte files, and one file with a bunch of numbers and .autosave as the file extension. I renamed the folder, opened the program without the error message. Then I deleted all those files, so far so good. BTW, my older versions of PSP have no autosave file in their respective temp files folder.
ADonahoo
ram: 24GB
Post by ADonahoo »
Problem solved. Thank you both.
