I've got two issues.
First, I've got an issue where audio becomes delayed after rendering. I"ve seen a post about this but it didn't seem to have a resolution.
So before I try to find a solution to that, I wanted to update VS x9 to SP4.
I'm on a brand new computer because my old one would shut off during render. I mean no BSOD...must whamo! All systems off!
So, I got a refurbished HP with the system specs you see to the right. I added an additional 8GB of ram. Everything seems to be running fine (this thing is fast). After it was all up and running with all updates, I installed VSx9 and have rendered some home videos and they are mostly OK except for the above mentioned audio sync issue. I was able to get the blu-ray authoring tool reinstalled as well.
So, when I tried to install service pack 9.5 (because you need that for SP4) I get the error as seen in the attachment. In case it doesn't show up and you don't want to open it, it says the following:
I have no option but to exit out.The installed version of the application could not be determined. The setup will not terminate.
The system has not been modified. To install his program at a later time, run the installation again.
I've tried to install SP1, but no dice. As well with SP2.
Any ideas?
complete uninstall and reinstall?
