Need suggestion specs for editing CVS Multicam projec
Chaofei
motherboard: ASRock H61M U3S3
processor: Intel I5-3570
Video Card: Nvidia GTS -1050
sound_card: Realtek onboard sound
Monitor/Display Make & Model: Samsung 22 Inch
Corel programs: Corel Videostudio X9 Ultimate
Post by Chaofei »
Hi guys,
I hope you guys give me some suggestion if i need upgrade my system hardware...
Currenly my main purpose for CVS is multicam project :
4 camera - 1920 X 1080 mts file
The problem is :
When editing MC timeline, the mouse movement is very slow, have to hold down the mouse for several second to running the preview windows ..... very frustrated
Currently my specs are below :
- Windows 10 pro
- CVS 9 patch 4
- Intel cpu I3-2120
- Ram 8 gb
- VGA & sound onboard
( got AMD 5770 no use cause not playgame anymore )
- 120 gb SSD + 4 HDD 1 TB
Any advice and suggestions will be greatly appreciated.
Best rgds,
Chaofei
Re: Need suggestion specs for editing CVS Multicam projec
Try using Smart Proxy for your MTS files.
Go to Settings Smart Proxy Manager, tick Enable Smart Proxy
Insert your MTS files to the library, use a new library page for your files.
Shift + Click to select your files
Right click clip selection and choose Create Smart Proxy files.
Takes a while to render, view settings Smart Proxy Queue Manager to view progress.
When complete Shift Click clips to select all
Right click for Multi Camera Editing—opens the editor.
Timeline playback should improve when using Smart Proxy.
Does that improve things?
Chaofei
Post by Chaofei »
lata wrote:Hi
Actually i have tried smart proxy early.
First enable smart proxy (setting menu smart proxy manager)
Insert file to created library
- shift click select all file
- right click and select files and create smart proxy file
- selected all and click ok (a window appear)
But in the Smart Proxy Queue Manager windows is blank, no file in the list !
Btw, thks for your help.
Chaofei
Post by Chaofei »
Step by step how i aply creat smart proxy file.
https://www.youtube.com/watch?v=JML5thO ... e=youtu.be
Correct me if there is wrong step....
Any help would be apreciate
The YouTube video is showing the process to create Smart Proxy, but something is wrong there,--- no proxy files are being saved? I have no idea why?
To create Smart Proxy files.
1 / go to Settings – Smart Proxy Manager- tick Enable Smart Proxy
Also from (F6) Settings - Preferences – Performance tab – leave all as default settings,(auto generate and Enable Smart Proxy should be ticked) you can select a different Proxy Folder.
2 / Adding video to the timelines having a larger frame size than 720 x *** ( as set in Performance tab) will have proxy files automatically created.
3 / To manually create proxy files, from library or existing timeline content, Right click any video clip and choose Create Smart Proxy Files. (shift+ click to select adjacent files)
4 / Proxy files do take a while to create so we can view the progress via Settings – Smart Proxy Queue Manager, here we can see the selected files.
5 / Once created the new proxy files should show in Settings - Smart Proxy File Manager, these files will have a similar name to the original video files.
In addition a small icon can be seen on all clips using proxy files, as image below.
click image for larger view
