After loading the latest update for PSP X9, my version is now 19.02.07.x64.
I find that only a few images are viewable in the 'Manage' screen. The images appear to be there but only as empty squares. Hovering the cursor over the blank square then displays the image information.
If I leave the Manage screen on for a while then further images slowly become viewable.
I am on Windows 10.
Manage screen not functioning correctly
john4647
- processor: Intel i7 6700 340ghz
- Video Card: NVIDIA GeForce GT 720
- sound_card: NVIDIA
- Hard_Drive_Capacity: 1TB SSD +
- Monitor/Display Make & Model: Dell 24"
- Corel programs: VS 2021 ULT, PSP 2023 ULT, VS2023 ULT, +
MarkZ
- motherboard: Intel DQ67SW desktop
- processor: Intel Core i7 i7-2600 3.40 GHz
- ram: 8 GB
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: LG Flatron E2241
- Corel programs: PSP 2018 X9 X8 X7 X6 ASP3 ASP
Re: Manage screen not functioning correctly
What you are describing sounds like the program creating thumbnails of the images. This takes time but I'm surprised it is as slow as you describe.
The more images in the folder that you select, the longer it takes. If you are using Computer in Navigation to select the folder, the thumbs will be deleted when you close the program and will have to be recreated each time you open it. To avoid that it is better to select the folders you access most often in Collections (don't select the directory Pictures; select the folders within that). The thumbs for those folders will be retained so the thumbs will not have to be recreated.
Mark
