VideoStudio X9 and X10 crashes on Rendering
Re: VideoStudio X9 and X10 crashes on Rendering
You do not need QuickTime Player, you should uninstall that.
But you may need the QuickTime Codec to play edit some mov types
There are a few YT videos describing the QuickTime issue, this may help..
https://www.youtube.com/watch?v=8lDOgqO_fVk&t
a_noob
operating_system: Windows 8.1
motherboard: ASRock A55M-HVS
processor: AMD Athlon II X4 641
ram: 6GB
Video Card: Palit GeForce GT 630
Corel programs: CD Graphics Suite X5, VideoStudio X9 Ult
Post by a_noob »
@Ron P.
K-Lite Codec Pack I installed a few days ago, and the problem with VS started to occur almost a month ago. Installing k-lite did not change the situation at all.
Hi a_noob
What are the properties of your MP4 video file?
Please right click a clip on the timeline or library and choose properties, what are they?
If you start a new project, add one of your files do you get a message to match the project properties.
If no – do you have Show Messages ticked in (F6) Preferences - General Tab.
Go to Settings - Project Properties, what are they? Are they the same as your video files properties.?
a_noob
ram: 6GB
Post by a_noob »
The project parameters are always set to the same as in the input files. However, I rendered in other settings and it was always good. When problems started I tried to render also on project/input files settings and nothing, it only helped to reduce the resolution, or change the codec to mpeg2.
Philippe Paris
processor: I7 740 qm
ram: 8go
Video Card: Nvdia 425 gtm
Monitor/Display Make & Model: Vaio vpc 13
Corel programs: Videostudio 9.5 ultimate
Post by Philippe Paris »
I have the same problem. Vidéos crash random when I render my project in mpeg 4 1920 x 1080 25p.. I have try many solutions but always the crash random. My file is one hour ten minutes long. Help me. Best regard
MrJohnny
motherboard: ASUSTeK COMPUTER INC. RAMPAGE V EXTREME
processor: 3.00 gigahertz Intel Core i7-5960X
ram: 32GB
Video Card: NVIDIA GeForce GTX 960
sound_card: onboard
Hard_Drive_Capacity: 8TB
Monitor/Display Make & Model: ASUS VH226
Corel programs: VS X5 Ult, VS X6 Ult, VS X9Ult,VS X10Ult
Post by MrJohnny »
a_noob
"When problems started I tried to render also on project/input files settings and nothing,..."
What does "nothing" mean? Does VS crash or hang or what?
What are the properties of the MP4 file - use MediaInfo in tree view to find out?!
John
a_noob wrote:The project parameters are always set to the same as in the input files. However, I rendered in other settings and it was always good. When problems started I tried to render also on project/input files settings and nothing, it only helped to reduce the resolution, or change the codec to mpeg2.
But what are they
please try to answer these questions
1 / What are the properties of your MP4 video file?
2 / Please right click a clip on the timeline or library and choose properties, what are they?
3 / If you start a new project, add one of your files do you get a message to match the project properties.
4 / If no – do you have Show Messages ticked in (F6) Preferences - General Tab.
5 / Go to Settings - Project Properties, what are they? Are they the same as your video files properties.?
a_noob
ram: 6GB
Post by a_noob »
@MrJohnny
"Nothing" it means still the same problem.
@lata
Input files:
H.264 Baseline Profile Video
24 bits, 1920 x 1080 , 25fps
Frame-based
23999 Kbps
After adding first file I get a message to match the project properties and click OK, then project properties - file properties they are the same.
On April 11th I edited the video in these settings, but I rendered using the following settings:
H.264 High Profile Video
Frame-based
15000 Kbps
The operation was a success. After a few days I finished another project using other files but it was recorded with this same device and with the same parameters and already during the editing problems started. Since then rendering always ends up crash, the first project also.
MrJohnny
ram: 32GB
sound_card: onboard
Post by MrJohnny »
Hi a_noob
"Input files:
Frame-based
23999 Kbps"
A project/input files with these properties previously rendered out to a file with the same properties - yes? But, now VS crashes?
Do you know if the OS has updated between the successful render and now? If yes, do you have a system image before the updates to roll back to? Then try rendering again.
John
a_noob
ram: 6GB
Post by a_noob »
Hi John
Yes, yes and I know :)
I have disabled updates and have not updated Windows for half a year. After the problems with VS I upgraded the system and there was no improvement, then I removed the updates.
MrJohnny
ram: 32GB
sound_card: onboard
Post by MrJohnny »
Hi a_noob
Thanks for the clarification.
Something has changed between the successful render(s) and the crashes!
Either -
1 The OS has changed
or
2 The programme has changed
or
3 The graphics card driver has changed.
Or a combination of same.
Can't think of any other pertinent element that could change.
You have confirmed there has been no hardware change to your setup.
Long shot – try setting up a new Administrator Account, then open VS and render the offending project that now causes the crash.
You may have to uninstall VS 9 again, then re-install under the new account.
John
To render, if you choose Same as Project or Same as First Clip instead of using this template, does that fail?
Do not use these.
Frame-based
15000 Kbps
Use these settings
Frame-based
23999 Kbps"
You say you removed the updates, are you referring to Video Studio updates, if yes how did you do that.
Please go to Help – About, what version are you using?
a_noob
ram: 6GB
Post by a_noob »
I apologize for my absence recently, time is killing me.
In the meantime, I continued to talk with Corel support. After zillion clean installs and dzillions of settings combinations, the project was rendered successfully. It helped to disable all hardware acceleration after clean install, which is weird because I tried it before and when problems started, hardware acceleration was also disabled...
So now it's good, and I hope it stays that way.
BIG thanks everybody for your help and once again I apologize for my silence.
regards
Arek
Helderhugo
motherboard: Asus M5A78L LE
processor: AMD FX 8120 8 CORE
ram: 16 GB DDR3
Video Card: Asus 1GB
sound_card: ASUS Xonar DS 7.1
Hard_Drive_Capacity: 500gb1TB4T
Monitor/Display Make & Model: LG 55'' 1080P 3D TV
Corel programs: Corel VideoStudio Ultimate X10
Post by Helderhugo »
Since Version X8 I am having issues with random crashing.
Now I am using X10 and the crashes are getting worse. Speacilly when I render more complex videos in 4K.
And it seams Corel doesn't solve this problem at all.
We buy Software from Corel for many years and the same problem is not solved at all.
What the hell are they doing??
Very disaponiting and frustrating.
This is intolerable in a company like COREL.
